Another "which Bilstein shock" thread
Bonestock
I know I'm getting Bilstein 5100. What I don't know is the length. I don't want to lift the rear any. It's a z71 burb. I am going to order eBay keys to level the front out. Should I add those jounce things too? I imagine I'll need 1.5 minimum in the front to level it. Also when if at all should coil springs be replaced? I was planning to go with the atomic coil over kit but I can put that $600 extra toward a 6.0 swap next spring.
JayXSP
Wallingford, CT
Im pretty much doing the same thing you are. Im ordering:
fronts - 24-186643 (0-2.5" lift)
rears - 24-185783 (0-3" lift)
ford keys - XL3Z5B328CA
old part numbers for the shocks were
Front - F4-BE5-C153-H0
Rear - F4-BE5-6682-H8
Good luck
Drewphil
