Alarm Gurus come in
Donkey Punch
Panantukan
So I have an Autopage Rs 1000 alarm on the yukon and for the past few days I've been having an issue with the remote start. The vehicle starts like normal when using the remote start.. idle for about 10 seconds then shut off.. then it will immediately try and restart and just die. Otherwise the alarm and vehicle seems to be working just fine. Any Ideas as to what to look for. I've had the alarm for about 5 months
chip
Cincinnati
Safety switch? Tach wire? Not too sure really. Did you try checking your troubleshooting guide, or calling the tech line?
Krazkix
The D'
what interface are you using to bypass the passlock system/control door locks? I'm using a Flashlogic FLCAN which also turns on my heated seats when I remote start...
tom q
Modesto, CA
I have the CS 700 which is very similar to the CS 1000. I have no problems with mine. I did not hook the tach wire anymore coz I programmed it via current sensing. Kill switch has to be grounded. I am using a GMDLBP bypasss.
Your problem sounds like a programming issue. If there is something wrong with the way you installed the alarm, it won't start.
01TX_Tahoe
Semper Fi
Pasadena, TX
i agree. sounds like a programming issue. i'd try to re-program it with current sensing tach instead... see if that works.
JeffK
