Added some exit lighting
gibbygsxr
Kingston, NY
Truck didn't come with the puddle lights so I made my own. Uses some DRL led lights and wired them to the reverse lights so they come on when you unlock the truck.
NathanJax
Vacation Nathan
Jax, Fl
Does that mean they also come on when you reverse?
fiatdale
Houstons Best
Houston
It'll look like the DeLorean getting ready to hover when you throw it in reverse! I think thats more geared toward rock lights. The puddle lamp gives light right to where you'll be stepping out. It looks like the light cuts off at the rocker panel.
Looks good otherwise though.
ezdaar
Chat Troll
Redneck central, Aka Houston
Was toying with the same idea the other week.
Had mine temp wired to the white door lights at the junction box in driver footwell.
Have not decided if I like them enough for a perm install tho.
Top pic shows LEDs stuck to very bottom edge of body. Second shows LED strick stuck up inside underbody.
Goodinblack
I Like Tacos
Dirty South
What LEDs you use?
ezdaar
Chat Troll
SUPERNIGHT (TM) 5M Waterproof 5050 SMD 300 Epoxy LED Strip Light White
If you want multi color with out a pos controller to burn out.
Use this 4 position rotary knob and these LED strips.
This will get you red, blue, green, and with 3 diodes, white.
If you want "RF" not infared control over RGB color mix, use this RF RGB Controller
Im currently working on a RF controlled RGB cluster, window, lock, dash and under body kit, but dont know how far I want to take it.
Goofing around with two strips, one RGB strip set to blue and a seperate white strip running side by side..
These are VERY bright at night. almost too bright. again, was just goofing around, they was taped up into the body with clear packing tape for funs.
Pure Blue.
byrds6
FL
Out of curiosity, on the 07 Tahoe are the red reflectors in the doors suppose to be lights?
byrds6
FL
Where are light housings in the front doors? The red reflectors im talking about are there. I see no other lights.
byrds6
FL
No I have a red reflector piece there. Its solid red no white and no light from either door.
NathanJax
Vacation Nathan
Jax, Fl
See post 7 in this thread. You don't have those lights in your door?
It's solid red in everything except the Escalade. Here's more info with pics and part numbers to swap them out
07 Tahoe Front Doors' Flood Lights
byrds6
FL
Your link went to a tilt column issue thread.
mfinta
