ABS and Break lights come on
2001yukonxl
I have a 2001 Yukon XL. Recently my ABS abd Brake Lights came on after I start the engine and while driving. Note : they go out after the start up, but they come on sometimes after. This behavior is not consistant. I have cleaned my ground contact under the driver door, no change. any ideas what may be the root cause ?
Thanks
Frank
SunlitComet
OBS Jedi-Do Good
unknown at this time.
you are in the wrong forum but for a 2001 i would say your connectors are dirty on the abs electronic brake control module on your left frame rail causing solenoid errors to be reported. disconnect the wire plugs and inspect.
Drewphil
