95mm throttle body compatibility
Too_L8T
Does anyone run part number 12669871 on their 6.2? Its the 2019 supercharged corvette TB. Thinking about putting one on the 6.6L since the newer TB that comes on this crate motor is not compatible with the E92 ECU.
if the harness is the same and it bolts up then it should work, presuming you are using some kind of cai that will fit as well
NYBRD
Have it on my 5.3 no issues
i put the LS7 throttle body on 6.2l gmt900 plug-n-play, the silverado I used the katec
Too_L8T
Too_L8T
OK thanks for the info, I’ll go this route then.
NYBRD
It didn't need any tuning to run ? no idle issues ?
Ehhh good question I installed TB when I installed my cam so everything got tuned at the same time with BBP so on the caution side yes it prob does need some tuning.
1948Buickroadie
