6.5td problem with stalling and stuttering
norwegiantahoe
Hello i have a problem with my 1999 suburban 6.5td. when driving it suddenly starts stuttering and wanting to stall. When it stalls it is very hard to start again, bit easier when it sits for some time after stalling. Feels like it mabye doesnt get enough fuel.
Sometimes i can be very gentle with accelerating and i can drive it Home when it happens.
The things i have done to it is:
New liftpump
New pmd with resistor and not mounted on pump
New tank
New diesel filter
Cleaned battery connections
Tried to blow air carefully to diesel filter and to the tank, from lift pump.
And i have bleeded the diesel countless times from both filter and t Valve with steady stream.
The filter housing fills up quite fast when engaging liftpump.
After i blew air both ways it worked for 3 weeks or so, and now the problem is back
The starter is new and cranks good.
This is starting to make no sense of whats wrong so all help would be appriciated.
exp500
1. Describe the problem you are having in detail:
2. Year of truck/engine.
3. Odometer reading (indicate miles or kilometers).
4. Indicate the model number on the Injection pump (starts DS4 or DB2......).
5. Indicate if you know if it’s a 1500, 2500, 2500HD, 3500, 3500HD.
6. Do you have an EGR on the engine? (An F or an S engine code 8th VIN digit)
7. Air Filter condition (visual check).
8. Fuel filter condition (freshly changed, mileage since changed).
9. Location of PMD/FSD? (ex. on pump/remote over intake, behind bumper).
9a. If remote mounted, describe wiring harness (homemade or purchased from which vendor).
9b. Indicate the location and condition of the FSD/IP grounding wire.
10. Outside Temperature (C or F). _____ °
11. Service Engine Light while running?- on/off/intermittent
11a. Service Engine light does glow during start/cranking/bulb check: Yes/No
12.Have you scanned for engine codes? Yes/No
12a. List exact results on engine codes.
13. Condition of Battery terminals (removed, cleaned and tightened).
14. Known condition and age of Batteries.
14a. Are batteries a matched set of same age?
15. Condition of Major Grounds (removed, cleaned and tightened)
15a Have the batteries been individually load tested?
16. Does engine crank, or "turn over"?
16a. Does engine start and run?
17. If engine does not start- Crack injector line: do you have fuel? Yes/No
18. Does your Wait To Start light come on?
18a.Number of seconds WTS light is lit.
19. Engine Cranking speed (if you have an accurate tachometer).
20. Are you experiencing Stalling?
20a. Describe the event (upon startup only, down the road, hit a bump, etc...)
20b. Do you notice loss of dash or instruments?
21. Check turbo inlet and air filter for obstructions.
22. In a no-hot start, pour a bottle of room-temp water on the injection pump. Does it start now?
23. Lift pump test - Describe results.
24. Upon cold start, does the radiator hose get hard quickly? Yes/No
25. Upon cold start, do you have excessive white smoke? Yes/No
26. Do you have excessive cranking time before the engine starts? Yes/No
27. Have you used the block heater? Does it affect engine starting? (only try for starting problems).
28. Are all glow plugs in proper working order?
29. During hard acceleration, do you have excessive black smoke? Yes/No
30. Do you have any unusual exhaust smoke issues?
31. Turbo check out - Pass/Fail
32. Indicate fuel that you are using: Bio-Diesel, #2 Diesel, SVO/WVO, other
32a. If running Veggie Oil fuel setup, indicate details of your conversion (homemade or packaged system).
33. Are you using any fuel additives? If so, please list.
34. Upon unscrewing fuel cap, do you have a large vacuum formed in the tank? Yes/No
35. Do you have any service history available that might pertain to the problem you are having?
36. Please indicate any modifications to the vehicle that might help us diagnose better.
exp500
Will my truck run without the lift pump? Yes it will. How well? Well, to some it will be very noticeable when it’s not working. Some may not even notice.
If I don’t notice that my lift pump isn’t working, I’m okay right? Not exactly. That means that your expensive injection pump is doing all the work in the fuel system. This is NOT a desirable thing. Plus you are setting yourself up for problems*.
How can I tell if my lift pump is working? Do the famous “lift pump test.” How do you accomplish this highly scientific experiment you ask? Very simple. Pop the hood - you’re half way there. Find on the front top of the engine the thermostat housing. You should see a little T-handle valve standing proud there in front of you. (If you have a van, you’ll have a schrader valve down deep behind the oil fill) That T-valve is calling your name saying “turn me.” Pay attention, ‘cause there’s a hose on the end of the T-valve. That hose should have diesel fuel come out of it when the engine is idling and you open the T-valve. When you open the T-valve and the engine is idling, and no fuel comes out, you’ll hear your engine cough, sputter, and die within 30 seconds. If it doesn’t cough, sputter and die with the T-valve open and no fuel coming out, something is plugged up in your fuel system between the fuel filter cannister and the t-valve, perhaps even inside the fuel filter cannister.
If the engine does die, it has emptied the fuel cannister and run out of fuel, so you will need to close the T-valve, then troubleshoot and repair the lift pump system, as follows in the text below.
Now, if you get a continuous stream of fuel out the hose, then close the T-valve and open the plastic air-bleed valve on the top of the metal filter cap - if fuel spurts out there, then congratulations! You are the proud owner of a working lift pump. Not everyone is as blessed as you are at this moment. If you're not, keep reading.
To those not as blessed, pickup reading here. You must determine why you have no fuel supply coming to your injection pump. There are two main culprits to the demise of a lift pump. Either it’s out to lunch, or it’s in the morgue. See, one means it still might work, the other means it’s dead. How do you tell? Check to see if it has power.
First, find the lift pump under the truck. With the engine idling along, pull the plug for the lift pump. You can either use a test light, or a meter to see if you have voltage at the pins. Make sure you get a good connection, otherwise you may condemn the wrong thing. Sometimes it is difficult to get a probe to meet up with the pins inside the plug, so make double sure you’ve got it.
If you have voltage, *chances* are you have a dead lift pump. Not always, but could be a dead lift pump. You may have voltage present under a "no load" condition. This means that voltage may be present when the lift pump is not attached to the circuit, but once the lift pump is connected, the load exceeds the amount of power the circuit can provide because the OPS contacts are creating a high resistance. For more information on this see this thread on electricity and how it can affect your voltage readings with loads and no-load situations.
Now, if you don’t have voltage, you’ll have to verify upstream from there why there is no voltage present. What is upstream? The infamous OPS (Oil Pressure Switch), or fuse.
What does the OPS have to do with the lift pump? Doesn’t sound right does it to have oil pressure tied to fuel does it? Well, some think that it is a fail safe that in case your engine ever lost oil pressure, it would shut off the lift pump so that engine would stall. Guess what? If you read a little bit ahead of this paragraph, you’ll find 'dat ain’t so'. The real reason why this circuit even exists is because of an accident. In case you should be in a wreck, the last thing you would need is to have your lift pump going to town pumping out that precious, expensive, fuel all over the accident scene. After all, should you be bleeding and having a thumpin’ head - the last thing you’ll be thinking is “Hey, I just paid $2.50 a gallon for that, somebody get a shop-vac!”
Why would the OPS not allow my lift pump to work? Well, from time to time, or shall we say in the corporate world, from dime to dime, some decisions get made. Some for the good, and some for the good of the keepers of the money. The OPS has a set of contacts inside to power the lift pump. This set of contacts are not heavy enough to carry the pathetic amount of current to the lift pump. Sad, I know, but true. So, what ends up happening is your lift pump works fine, but the OPS gets smoked, and then it quits. You think the pump is bad, but it’s not.
Can I just eliminate the OPS? Well, be careful, it is a safety device in some people’s eyes, and to the rest of us, a pain in the rump. Eyes, rump, pick your part. Anyway. If you just “jump past” the OPS, then your pump will run all the time. Not just all the time, but ALL THE TIME. Christmas and Easter included. It will stop when your batteries are dead. Because, while you are grocery shopping, that pump is running. While you are down for a long winter’s nap, it’s pumping. Doesn’t matter if the key is on or off, it’s pumping.
You can make up another circuit and repower it some other way, but be careful how you do it. Some methods have kept the truck running after the ignition is shut off and keys in pocket.
Back to our little friend the lift pump.
The lift pump may fail in a variety of different ways. It may fail “open” meaning that the coil driving the pump no longer has continuity. It may fail mechanically where it is just frozen and nothing moves. It may even (not as often) fail to pump. This means, it makes noise, but doesn’t actually pump.
Does the lift pump make noise? Yes it does. The model year of your truck will determine if your lift pump is powered during the Wait To Start period. That’s the time where that light is on before actually starting your engine. '96-up OBD2 models pre-run the lift pump during WTS and during START, '94-'95 OBD1 models pre-run the lift pump only during START.
The lift pump is characterized by a kind of “purring” noise heard beneath the truck. That noise is quickly drowned out by the engine, once started. When you shut your engine off, you will hear that pump run briefly, maybe only a quick second or two. If you shut your engine off when cold, you will hear the pump run much longer, sometimes up to 30 seconds or more.
A loud clacking noise would indicate no fuel from the tank, or the lift pump is failing or failed - it will run without pumping fuel when the one-way valve(s) fail.
A faint purring or vibration when touching the lp body indicates it is running, but the internal valve-shuttle armature is stuck due to mechanical failure.
So what kind of problems will it cause if the lift pump isn’t working? Many. It will cause all sorts of fuel related issues*. It can be some of the following:
°Stumbling
°Hard Starting
°Lack of Power
°DTC (Diagnostic Trouble Codes) on the Computer
°Stalling
There are be other* issues too, but these seem to be a very (un)popular list.
I recommend Diesel Place forums for finding your problem. Hope this helps.
JPeter
