4x4 fuse keeps blowing 1997 Tahoe 2 door
RedCrush
okay, heres the deal, My fuse keeps blowing on the 4x4. And it does not blow right away. I can put into 4 high of 4 low and offroad for like 5-30 minutes than the fuse pops. This is what I have done. New front actuator, 4x4 was working properly but i had to change the transfer case due to an internal problem and blow out on my old one. Replaced with "low mileage" transfer case from junk yard. Is there a sensor or anything I should have perhaps removed off my old case and put on the newer one? it seems like this started with the new tranfer case.
---------- Post added at 05:00 PM ---------- Previous post was at 04:57 PM ----------
oh yeah, I don't see any shorted wires leading to the front actuator and the wiring harness was close to my exhaust manifold but I moved it away enough so it wouldnt be touching.
RedCrush
RedCrush
fuse box, numer 23 or 24, cant remember the exact #
SunlitComet
OBS Jedi-Do Good
unknown at this time.
there is the transfer case switch on top of the unit that switches power to the actuator. looks like this.
RedCrush
RedCrush
i replaced that switch over the holiday and it seems to still pop the fuse it will shift into 4 low still and work properly, but after a few minutes the fuse still pops.
AZ Tahoe
Arizona
Just wondering what 2 fuses run the system? And is this for a floor shifter?
---------- Post added at 09:52 AM ---------- Previous post was at 09:32 AM ----------
Just looked at my fuse box and #2 is trans case and #24 is 4wd. #2 in mine is an empty slot and now makes me think this is why my 4wd doesnt work
QuasiInrem
