4WD transfer case or tranny broken
FiatBen
northwest Arkansas
While attempting to fix a problem with the truck randomly shifting into 4WD, I think I broke it.
I pulled the encoder motor, front driveshaft, front actuator to test the motors. I believe I failed to align the encoder motor and transfer case to neutral when I put things back together. When I started the truck and engaged the shift selector (selector was in neutral at the time) there was a disturbingly loud slamming noise and it jumped into 4WL. Now, there is a horrible noise in Park, no noise in Neutral, and the truck will not engage either Reverse or Drive. Any idea what I broke? I don't mind changing out transfer cases if that's the solution, but I'm not skilled enough to pull/replace the tranny. Anyone else have a similar experience or a good guess as to what I've done and whether it's repairable? TIA
'04 XL SLE w/ 5.3 and the 4:60E, 252K miles
Moderator
People's Republic of Colorado
What make, year, and model?
@rockola1971 for comment
Pull the encoder motor off and manually shift the transfer case into 2hi. Leave the encoder motor off (strap the wire harness away from the driveshaft) and see if the noises go away.
Then line up the encoder motor correctly. I asked about what year because of the differences in the shift shaft (two flats vs splined).
F
FiatBen
northwest Arkansas
My bad, neglected to spec the truck, '04 XL SLE w/ 5.3 and the 4:60E, 257K miles on it. Shift shaft is splined. With the encoder off, and trying to engage 2H, still a rattling noise in park and nothing else; quiet in neutral, not engaging reverse or drive gears.
rockola1971
Indiana (formerly IL)
The symptoms described sounds like one of two things have happened. (1) Transmission Sunshell busted its weld. (2) Tcase had a stretched Drive Chain. The best thing to here now is drop the Tcase and inspect the case for damage from the Drive Chain. Block the wheels and start engine up and put in Drive (vehicle wont go anywhere withe both driveshafts and Tcase removed) and verify output shaft of tranny is spinng. If it is not then Sunshell likely broke. If it is then Tcase is the cause.
spectol
