3" levelling keys/rear leaf block kit for 2500?
at100plus
I'm shopping for the levelling keys with 2" blocks for rear leafs on a 2004 Suburban 2500.
Are aluminum rear blocks in fact better?
Any brands to stay away from?
I see them on eBay for anywhere from around $110 to $190 for the kit that includes the keys, front shock mount extender and rear blocks.
I was thinking about getting this CTS kit:
http://www.ebay.com/itm/371216849273?_trksid=p2055119.m1438.l2649&ssPageName=STRK:MEBIDX:IT
Fat Bobs kit $189 is it better? (
http://www.ebay.com/itm/370380294603?_trksid=p2055119.m1438.l2649&ssPageName=STRK:MEBI
One on Amazon for $144
http://www.amazon.com/gp/product/B0...rue&ref_=ox_sc_sfl_title_2&smid=AOPDFBNVJH953
OR???? Should I pay more and stick with a known seller in the 4x4 biz for apparently the same product???
Last question:
I'm only running 275/75/16 Good Year Duratracks and don't plan to go bigger. I could probably level it out with the stock keys and be satisfied. I was just tempted to go about 2" higher with one of these kits.
Anyway If I just jack up the stock keys to see how I like that, do need to get an alignment done or is there an adjustment for the camber that I can do myself? Will the camber be out causing the outer edges of the tires to wear if camber is not adjusted?
A
at100plus
TTT anyone? Rough Country seems to be the consensus so far from others I've asked.
You might have better luck posting this in the Lifted Suspension section. We're all about lowering here in the Street Suspension section!
johnsonwillie199
