24" tire sizes For 2017 Tahoe
Dmastro
Was looking for some info on the best tire size to run on my 17 with a 2 inch level and 24" rims
ivin74
05 NBS Nali
Htown, Texas
When you say level did you lift the front or lower the rear to make it level? Are you looking for an all season or an all terrain tire?
Dmastro
Dmastro
Front level only and I'm looking to put on some all terrains
Dmastro
Dmastro
All terrains and I only leveled the front just wasn't sure what the biggest size tire I could run with 24s without any issues
RThomasII
Maybe re-ask your question in the Lifted Suspension/4wd section (they would know) but my guess is the sweet spot tire size for a 24" rim would be something like 305/35R24.
Regarding wheel/tire combinations that will fit your truck without rubbing, no 2 trucks and their suspensions are exactly alike, due to a number of factors including accumulated wear on the suspension components, so there is no guarantee that what fits with no rubbing on one truck will automatically fit with no rubbing on your truck. Other folks' experiences can guide you in one direction or another, but the final test will be when you mount the wheel/tire combination on your own truck.
To assist you in getting a good idea on whether or not specific alternate wheel/tire combinations 'may' fit your truck with no rubbing, I recommend that you use the wheel/tire comparison app at the URL listed below. You can use this app starting with your existing wheel/tire combination as a benchmark, assuming that there are currently no rubbing issues with it, and measure the actual critical fender and suspension component clearances as directed by this app. Then, you can enter alternate wheel/tire combinations, and this app will give you the projected changes in these critical fender and suspension component clearances.
https://www.wheel-size.com/calc/
I used this app for determining whether on not I could use my current alternate wheel/tire combination, and it accurately projected the changes in critical clearances. Again, the use of this app in not an absolute guarantee that an alternate wheel/tire combination will fit without rubbing, but it provides a much better assessment, or projection, than simply an educated guess on your part, or a statement from others that it worked on a truck other than yours.
JPeter
