2025 Yukon Garage Remote Programming
Jayhawkeye3
You don't need to put the garage door in learn mode. All you have to do is hold the remote up to display and push both buttons at the same time to get them to synchronize. I have the exact same opener, and it took it the first time no problem. Learn mode on Lift masters is only when you are attaching other handheld remotes or a remote door keypad.
Problem is I don’t even have the remote anymore!
Fless
Moderator
People's Republic of Colorado
Remotes are cheap ($6 for 1, $10 for 2, etc.) on eBay. Just bought a few for use at several places and they programmed easily. They can be programmed for the newer MyQ openers or my 22YO Craftsman/Liftmaster. For compatibility verify the color of your opener's programming button.
I bought from here: https://www.ebay.com/itm/388776761932?var=655890469577
EDIT: For security purposes it may be advisable to clear the opener's memory before attempting to program new remotes. If remotes have been lost but are still in the programming, they can be used by someone else to open the door. Clear the memory and program the external keypad and all the remotes you have.
Forevr2whls
I finally pulled the negative battery cable for a little bit. I was able to program the remotes again after that. I hope it doesn't happen again.
Hello CrashDavis. We are experiencing exact issue with the homelink in 2025 Tahoe high country. Did you have any issues after disconnecting the ground cable to battery? Any other reprogramming needed or other electrical issues? I thank you!
Saltydog
Add me to the list, been fussing with this for wayy too long. It worked once and now I can’t add or delete remotes.
LegalBrief
Senior Member
Problem resolved with 654 … do the updates (2) and u need a fully charged battery to get them to run
Eickybobby5050
