2024 Tahoe Seat Shifts when Stopping and Accelerating
chaser
Hello.
I have a 2024 Tahoe Premier. The driver seat has noticeable movement front and back when stopping and accelerating. When accelerating, the seat cushion moves up and down slightly. When stopping, the rear seat back moves forward slightly. It feels like somebody taps the chair in either scenario. There's an audible tap sound. There's not any left to right movement.
I can recreate the issue by either lifting the seat cushion up and down from the front of the seat, or by pulling and pushing on the rear seat back. The movement appears to be coming from the joints under the seat that allow the power seats to change position. It seems like they allow for too much play or aren't tight enough causing the "slop" as I can best describe it.
I've searched this forum, google, and social media. All I can find is earlier models with lateral movement. This is different.
The vehicle is under warranty. I will be dropping it off for diagnosis and hopefully repair. Has anybody else experienced this with a 2021 through 2024 Tahoe or Yukon and found what fixed it?
Cheers
2024 White Tahoe
Hello.
Cheers
I have a 2024 Tahoe Premier 4WD - build date of 9/2024. The seat has no play or slop.
If you can demonstrate the movement to the dealer, they should replace the power seat track assembly.
KMeloney
I think you'll find that it's NOT different. There's play in the mechanism under the seat which allows it to rock/slide in some way. (Had the same issue on my C5 corvette -- and it was a wide-spread issue in that model.)
There's a retainer/clip that your dealer can install that may solve the issue. Or, they may have to replace the mechanism under the seat.
Either way, I hope you'll come back and post exactly what the diagnosis and remedy were once it's fixed.
CiscoKid
Virginia
I agree with what KMeloney said above. Very common issue with C5 Corvettes. They call it "the rocking chair". Do a search and you shouldn't have much trouble finding a video to help you.
Durobans
