2021 Tahoe Sunroof drains…
Bthnc
Hey all, my 21 premiere sunroof is leaking. I’m aware of the TSB, but it will be a bit until I can get the truck in. Are there only the 2 drains in the front of the roof area? Anything in the rear?
I ask because I think my leak occurred when the truck wasn’t even in use, but was in some rain and parked on a slight upward incline. I tested pouring some water into the channel and in this case, water went to the passenger rear where gravity was pulling it. Instantly dripped inside. When I turn the truck around so it is on a slight decline, it drains fine. So, was trying to figure out if there are any drains on the rear side and where they are routed.
Thanks!
BG1988
4 of them pour water down the drain, check for cracks
Escalade2007
