2021 Tahoe Shakey at 80mph
uptown_nyc
Driving a 2021 Tahoe - have about 4k miles on it, and am noticing that as I approach 80mph the vehicle begins to shake. I'm guessing it's a wheel balancing issue. Maintenance chart calls for rotating the tires at 7500 miles, and I'd have their balance checked then -- but was just wondering if anyone else has experienced this with the new models and if there's anything else I should be looking for before bringing it in? Any downside to rotating / re-balancing earlier than the 7500 on the schedule, or does anyone recommend a different schedule than what the manual calls for?
Quark
Atomic Nuclei
Could be a tire problem if so be prepared for GM to tell you to go talk to the tire manufacturer.
Kpwweb
11k with nothing like that. It has been my experience that shakey at certain speed is a tire problem - imbalance, shifted belt, bulge, etc.
Blueinterceptor
I had a problem like that. I do a lot of highway driving. I initially had my tires road forced balanced.
here’s what I’ve experienced. My tires operating temperature
while cold 36 psi would shoot up to 40-41 psi after an hour of 65/70 mph driving. I lowered the cold psi to 35 and operating temp went 39-40
I had a slow leak in a tire that they could not find and after a few trips to the dealer, we decided to change the stem. After they changed the stem, they found the nail in the tire. For what ever reason, the truck developed a shake at 70 plus mph afterwards. I assume they didn’t balance the tire or didn’t do it correctly. I took the truck to a tire shop and asked them to rebalance the tires. I had asked for road force balancing. I was asked why and was told, that rfb is most useful on a defective tire as it balances the heaviest part of the tire opposite the heaviest part of the rim (if I remember correctly). I went with regular balancing. The truck rides like it is new. The cold psi is 36.
the operating temp has not exceeded 38psi since. The truck rides quiet. Ymmv
tom3
Had a similar problem some years ago. Took it back to the dealer and they road force checked and balanced all four, had to replace one tire to get it into specs. They did give me a full spec sheet on the results. But the SM also said that they see this some on black vehicles as there is an extra heat for paint curing and the tires get some out of whack once in a while. Don't know if there's any truth in that or not - but they sure got it perfect. I'd have a talk with your service manager before doing anything else. Some will really work for you, some won't.
Big Mama
Virginia
My rig is much older but I had a shake at 75, no slower, and no faster. Tire balance. But also found a slow slow leak in the right front.
Denali Brad
Are they still using the Bridgestone Alenzas as the factory tires?
At about 5k miles I ended up throwing mine away. Balanced 2x, RF balanced and finally went to a known problem solver. He put them on his machine and they were balanced, but out of round, and that was causing the shaking.
Put on a set of Michelins and no more shake.
Good luck...I know how annoying it is.
Rotate the tires at every oil change and don't let the oil get older than about 5,000 miles. Your tires and motor will reward you with longevity and smooth operation.
A shake like that is a tire balance issue.
SSGUNNER
Could also be a simple issue as wrong weights. I also had a similar issue about a yr ago previous ride, new tires and had a small tire shop install and balance. After a few days noticed shaking at about 80mph and went to another bigger chain tire shop and confirmed weights previous shop used where wrong. After that no more shake or wheel hop.
U
uptown_nyc
So I took my Tahoe into the dealer yesterday. The woman at the service desk's first response was ... "you're not supposed to drive over the speed limit". I thought she was joking but realized that she was serious. I understand that maybe dealer service departments don't have a dyno that they can test these things on (they really should), but her response floored me. But after confirming with her colleague that they could in-fact check this problem out, they did take my vehicle out for a drive.
They concluded that they did feel what I reported, and have told me that the left rear wheel is slightly bent.
New car. ~5600 miles. I've never bent a wheel in all my years of driving. Haven't hit any major pot holes with this vehicle or driven it over anything notable enough that should have caused a bent wheel, but here we are. Was it bent from the start? Maybe - probably didn't do much higher-speed driving till recently, but I have no way to prove it. Anybody have suggestions for how to remedy apart from just replacing the wheel, which they quoted me ~$550.
I'm planning to take it to a tire specialist to see if they have a different conclusion.
U
uptown_nyc
So I took my vehicle out on the highway yesterday and got up to highway speeds where it had been exhibiting the shake. No shake at all. I have no explanation for why it's gone. As far as I know, the dealer didn't perform any mechanical fixes on the vehicle. I don't believe they removed the wheels - but perhaps they did, or perhaps they tightened something?
I'm happy -- but dumbfounded.
brice715
