2018 RST tahoe/burb
jeffbco
Fifty
Yes. It's a generic photo and I can't tell which family caliper it uses.
Some of the "generic" brembo's flex so much any gains from pad size or rotor diameter is lost in feel and clamping power at max use.
fozzi58
North Jersey
When the the calipers on my Avalanche froze up I replaced them with Powerstop units which basically were re manufactured stock units with slightly larger pistons and bored fluid holes. They do well with the added steel lines, the better pads, and the drilled/slotted rotors.
However on my go-fast cars, I've used Wilwoods a couple times and they are excellent. They make a set for the 2015+ SUV. As an added benefit they are about $1000 cheaper than ordering your truck with them or $3000 less since you don't need to buy factory 20" rims if you intend to put some of your own wheels on eventually. Wilwood makes a 16" rotor that requires a 20" wheel or bigger and smaller rotor for 18" wheels.
I can't see the quality of the SUV brakes being sub-par to the cars. The set I looked at for my upcoming burb purchase look almost identical to the 6 piston sets I put on my 87 Trans Am 20+ years ago and the set I put on my 00 TA back in 06. Since I have used 2 sets of Wilwoods over the span of 20 years and got more than I expected both times, I would expect them to perform the same or better with this upcoming purchase. Might be something you want to look in to.
Fifty
Brembo makes about 12 different families of calipers. Each to a different price point and use. The bottom two tiers are extremely flexible due to body material quality and they being two piece calipers, using binding bolts that stretch quite easily as well.
For a simple quick comparison, google stoptech vs brembo and they put a gauge on a set of 6 pot brembos off a BMW m car and a stoptech str-60. The brembo flexes about 10 times what the stop tech does.
I have a SRT charger with those brembo's and my race car originally used cheap brembos but now uses the stoptech. The difference in pedal feel is astounding.
Usdmskyline20
Any update on the window trim wrap?
Dropped the truck off last night to get the windows tinted and the chrome window trim and mirror wrapped as well as the tails smoked. I'll post some pics later this evening.
Usdmskyline20
No. It wasn't done. When I went to pick the truck up the guy who did the clear bra said the guy who does the wraps had to leave and goto Miami and didn't make it back in time. So still rocking that chrome
Came out really sharp looking.
Usdmskyline20
Looks sharp, any pics of the tails after they smoked them?
Yeah. I need to take some pics. They aren't as dark as I'd like but it looks good. I'll try to post some up tonight. Hopefully I'll be able to drop it off to the paint shop mid month to color match the chrome grill.
Denali132
Banned
I like this package a lot, while its not an all out crazy HP package especially for the suburban, gives more option as far as styling
I had a guy wrap all the chrome around my windows for $60 on my Suburban and it came out good. He does tint on vehicles and does all of mine and this was the first time he ever did the vinyl wrap
Da Hawk
I just got a quote today from a shop that was working on a re-tint on my daily driver. I asked about just wrapping the chrome window strips on my wife's Tahoe. He quoted me $1,200 - $1,300!!!!!!! He said that they use 4ft wide wrap and that's why it's so high. I looked at him all crazy like he had a second head attached to his shoulders. I walked out of there in total disbelief. NO THANKS!!!
Usdmskyline20
That seems a bit much. I paid $200 to wrap the chrome around the windows, mirror and smoke the tails.
gat0r
DFW
is the tahoe still the only one w/ option of 6.2L? as all orig media said hoe only & no burb.
if so, that sux.
b4z
if so, that sux.
Yes,no 6.2l for the suburban. I don't get it either. And also don't get why the 5.3l still has the 6 speed. Ford may have leapfrogged gm with the 2018 expy.
15YUKON
That's cool you can get the 6.2 in a Tahoe. I think Ford should put their 6.2 in their platinum expy it's a great engine. I'd imagine MPGs would be lower due to no cylinder deactivation. Why doesn't Ford invest in this tech like GM? It's nice to have displacement when you need it.
CKendrick
