2017 GMC Denali..
Shaggy
Admin/Owner
Arizona
Question.....on take off(from a stop position) is there a delay feel to it when you hit the gas, where it feels like its just not taking off right away and waiting a few seconds to finally pick up?
Test drove one and was curious if it was just me as I am used to my 06 Duramax taking off right when I hit the pedal or is it an issue with the Denali I test drove?
PG01
Up here to the right
When my 13 hoe was new it used to feel like that.... turning off afm and spaying the the tb w/some cleaner reduced it dramatically
sickk23
New Mexico
It's pretty normal and you'd get used to it. The best way to tell if it's not normal is to go drive a different one.
I'm almost certain that it's for fuel economy. It could benefit from a sport mode to sharpen throttle response but there's not one so the next best thing is a tuner.
cardude2000
Yes. Yes there is.
It would be acceptable if the engine had a start/stop function but alas it doesn't and it's just another 'unique characteristic' of these beloved vehicles.
I've learned to tap the throttle slightly before I want to actually 'go'.
adventurenali92
Big Bear Lake, ca
In the couple of latest gens that I've detailed, in moving them around and such, I've noticed that switching gears it lags. It doesn't roll right away when you switch gears and want to move. Not like my 2006 where I switch gears and it immediately wants to roll.
hunter991
I have the same thing on my 17 tahoe. I was told its to improve MPG. Eliminates jack rabbit accel from a dead stop.
my09denali
I've only had my new truck 2 weeks but seems like there is a "miss" when accelerating slowly from a stop. Right after I start to go it seems like the truck will go from 1st and then have a delay while it immediately goes to 2nd gear. I assume that is from the 8 speed. The dash doesn't say it is in V4 mode while it is doing this.
BMPNUGLS
Mid-MO
What your feeling is related to the AFM (active fuel management) programming. Get a Range Technology AFM Disabler and hesitation is gone.
cardude2000
Really? When I had my range I’m pretty sure I still felt it. Maybe I’ll have to get another range and test again.
jeffbco
AFM doesn't engage at idle so not sure how AFM gets the blame for this.
WillCO
Castle Rock, Colorado
I believe it's normal. These throttles are electronic, and there is a "curve" programmed into them that tells the car how much throttle to apply for a given movement of the pedal. Many reviews I read before I bought mine commented that the programming was a little lazy. It's probably about CAFE standards.
I got used to mine and don't find it to be a problem needing solving. If you feel otherwise, there are some aftermarket solutions that can reprogram the throttle to behave differently. One such product is called a Sprint Booster (link). These do not add any power to your engine, they just make more of your throttle available in less pedal movement and they do give the car a feeling of increased urgency.
Full disclosure - several years ago I tried one of these on a BMW 5 series and found the effect to be way too extreme for my taste. The device programmed all of the throttle curve into the first 35% (ish) of the pedal movement. I took it off after a week. It's a 5 minute install though, and apparently newer models have variable boost ratios.
cardude2000
What people are talking about is the delay in the power being created after you touch the pedal.
I usually tap the pedal a second before I actually want to go to eliminate the delay. I have no idea why its like that but I dont think it has anything to do with AFM or torque curves etc. Frankly its probably to keep people from complaining that the throttle is 'too touchy' lol.
BMPNUGLS
Mid-MO
AFM does usually engage as your slowing down if enabled...slowing down it usually goes to V4 and once you punch the gas a "slight" hesitation will follow...documented on many other forums that disabling the AFM helps significantly
WillCO
Actually I think we agree. The aftermarket products I mentioned have nothing directly to do with AFM. They do nothing more than re-map the throttle to be more "touchy."
cardude2000
Got it. Someone here mentioned the range device which has the sole function of disabling AFM.
cardude2000
OP is talking about hesitation from a dead stop.
soulsea
Bar
Probably driver error. :)
I'm sure a blackbear tune would resolve the issue, or maybe something like this: https://www.pedalcommander.com/prod...-v8-420-hp-2015-throttle-response-controller/
JeffK
