2007 Suburban LT - Buzzing sound from Radio
JochenWoern
Sacramento, CA
Interesting how many things I find out when I take care of the lovely ladies BURB and i get to drive it based on it needin gmaintenance taken care of (tires, oil change, etc.).
While driving, there is a Buzzing sound coming from the Radio, most noticeable at the rear doors, it appears it is coming out of the rear door speakers. As you accelerate, the buzzing sound follows the RPM range of the truck, gets lower when the truck downshifts. If I turn the radio off, of course the sound is gone. I can REALLY hear it with the Volume is at the lowest setting, (no radio noise coming out of the speakers), the buzzing sound is now VERY NOTICEABLE and totally annoying.
I do have the OEM BOSE Stereo system with the Rear DVD player in the BURB.
Any thoughts?
Thanks in advance.
Goodinblack
I Like Tacos
Dirty South
Back in the old days, didn't this have to do with spark plug wires causing the noise.
From MSD.
Radio Frequency noise is generated by the secondary side
of the ignition (coil wires, cap, rotor, spark plug wires). This
noise is radiated into the air and picked up by the antenna.
This noise will be noticeable on the AM band and will be
louder between stations. The FM band may also be affected
slightly. If you play a tape or CD, the noise will go away. Maintaining
the secondary side of the ignition system is important
in eliminating radio frequency noise.
http://www.msdignition.com/uploadedFiles/MSDIgnitioncom/Support/frm23758_tb_radio_noise.pdf
THE YETI
Director of Operations
South FL
Sounds like a loose ground or connection.
JochenWoern
JochenWoern
Sacramento, CA
Thanks guys.
Any particular area(s) where I need to be looking for the loose ground? How a
many areas/positions are on our trucks where the ground could be loose?
Thanks.
Goodinblack
I Like Tacos
Dirty South
I am not trying to be a smart ass, but may need to get a chilton's etc. diagram and start hunting.
OHSIXX
Milwaukee
Check the main ground off the battery to the chassis and check the ground for the alternator as well. If there is rust on the ground you may want to crimp a new end on and scrape/grind off rust. You want a nice shiny surface to have the best ground..........
I'd check alternator first as you described the sound following the RPM's......
Good Luck bud
JochenWoern
JochenWoern
Sacramento, CA
Good Luck bud
Thanks very much Jason.
JochenWoern
JochenWoern
Sacramento, CA
Went to the dealer for an oilchange today and asked my Service Advisor Bud to check all the grounds, ALL are tight and clean. :shrug:
blackbeast03
NC
Same prob...
I have the exact same problem, with the same Bose system....did you ever find a fix for yours?
jmgak47
Check your grounds as already stated. Also you you should try grounding the outside of your headunit and amp to the closest solid ground, has fixed lots of ground loop issues for people.
Ponchonutty
New Washington, Ohio
Also I have found in vehicles doing audio work sometimes the vehicle would have a battery or alternator going bad causing an overcharge condition. Sometimes the radio can pick this up.
Mike C
Any thoughts?
Thanks in advance.
Hello, I have an 2007 suburban with the same problem and silent misfiring coils where you can't feel the engine shaking, So I hooked up a scan tool and went to the live data option and seen when the buzzing started I noticed I had 3 bad coils, I changed the coil and the noise went away and so did the stabilitrack message
Drewphil
