2007 Drivers side blend door cleaning!!
Yukon/Baja
I had the same problem as others here with drivers side of dual zone a/c not cooling properly. I tried the resets suggested by other members but the drivers side was still a good bit warmer than the passenger. I removed the actuator, opened it up, and found the contacts to be very dirty and coated with the grease that's on the gears. Using electric parts cleaner and q-tips, I cleaned the small contacts on the gear and the area on the board that the contacts ride on. Reassembled, plugged back in, pulled and reinstalled fuses to do a reset, and problem fixed!! Drivers side is now blowing very cold and doesn't wander around like it did before.
It's kind of hard to see the contacts on the black gear in the pics because they were so dirty.
The whole job took maybe 30 minutes start to finish.
Hope this helps someone who's having the same problem!!
Hammer450R
Very cool, thanks for the write up! Im sure this will save someone in the future.
honistor
I have a 2004 Yukon Denali and was also experiencing the HVAC system blowing hot air when it was hot outside and cold when it was cold outside and everything in between. The system had a mind of its own. The problem was only on the drivers side. The passenger and rear zones were working fine. The day I finally had enough happened to be a Sunday so I couldn't get a new actuator from the dealer and the other parts stores in town had to order one. After reading many forums I decided to try cleaning the actuator and after 5 months the problem is fixed. I would urge anyone with a blend door problem to try cleaning to actuator first. It only cost me some time. My car has a center counsel so it was a bit of a chore to get the actuator off and put back on but well worth the time. Start to finish was only about an hour.
luv2cruiserccl
Michigan
Where would that be located on a 09 yukon xl. Having same issue but on passenger side
Sent from my SCH-I545 using Tapatalk 2
bmwme
Do you have any pictures of where this actuator is located under the dash? I am going to try this Sunday. I'm tired of my legs being cold!
bmwme
My 07 LTZ started blowing cold on the drivers side (I actually was thinking it wasn't blowing cold in the summer so now that's confirmed). I tried the reset a few times and nothing changed. I've heard there are a few kinds of actuators so I went in to pull it out and get the part number. While it was out I figured I might as well open her up and see if mine was dirty like the OP.
What I found was disturbing. Not sure why it got wet but it seems the actuator was submerged enough for the motor to rust pretty good. It was seized but I took all the sprockets out and churned the motor by hand until it felt better. I also cleaned the contacts like the OP did.
Figured I should reinstall and see if anything changed. I did the reset and I have heat again!!!! Feels so nice to fix this ongoing problem for free.
I'll take a photo tomorrow but once you drop the panel under the dash on the passenger side the actuator is in top of the trans tunnel. Two 7/32" bolts hold it in. Fairly easy job but fiddly.
luv2cruiserccl
Michigan
I photo would be great thank u I would love to try this mt self
Sent from my phone using Tapatalk 2- Please excuse any errors.
Goodinblack
I Like Tacos
Dirty South
That much rust on the motor is hella crazy........ could it be from some sort of condensation issue?
bmwme
Best photo I could grab at night, with my phone. The actuator is the unit with the red plug in the left side of the photo. This is with the lower panel removed.
So it's 3 10mm bolts to remove the lower panel, then the two smaller 5.5mm or 7/32" bolts to remove the actuator.
luv2cruiserccl
Michigan
Really I thought I read on line where whole dash had to come out is it really that easy?
FijiRob
Can anyone offer advice how to get that hidden bolt out on the actuator? It is the one towards the drivers side and I could not get anything in there to get it out!!
luv2cruiserccl
Michigan
I need to do mine soon I assume u have tried?
Sent from my galaxy s4 phone using Tapatalk 2- Please excuse any errors.
FijiRob
Yeah, I tried but there is not much room to get anything in there to loosen the bolt. Just checking to see if anyone had any secrets or tips on how to remove that hidden bolt.
77DLOVE77
St.Petersburg,Florida
Thankyou I just fixed mine.. Opened it up , cleaned off the access grease. Disconnected the battery for 5 minutes to reset.. A/C blows COLD!! ;)
JamesinAbilene
