2004 4.8 liter upgrade to LQ9 6.0 Liter Questions
mci007
Laguna Hills, CA
Has anyone done it, what should i look out for, I have a 2003 LQ9 motor and i want to drop it into my 2004 Tahoe, do I use the electronics from the LQ9 or can i use the wiring harness and ecm from the 4.8 liter motor that is going to come out of the car, Im assuming i need to use everything that is on the LQ9 currently, intake, injectors, fuel rails, wiring harness, ECM.
Thanks for any help.
bkboatnsleds
McHenry, IL
I just did the swap from a 5.3 to a Lq9....
I used all my stock wiring, Ecm, Fuel rails Intake etc. You should be in the same boat, as the 5.3 and 4.8 share the same stuff too. Was a fairly straight forward swap.. Do it! :)
Have to have the PCM Programed for the new motor.. thats all
I literally finished today
bkboatnsleds
McHenry, IL
how much does it cost to have the ECM reprogrammed.
I had mine custom tuned with someone who uses HP Tuners. Cost me $300.00 but that was for a custom tune, they drive it, watch all the parameters etc. Also when i update my exhaust and headers it will be re-tuned for no costs.
There are a lot of ways you can do have it done.
JKmotorsports
Austin, TX
It's a simple straight up swap. Assuming everything is good on the 6.0, you can just pull the 4.8 and drop the 6.0 in its place and just retune the pcm.
M
mci007
Laguna Hills, CA
if i have the LQ9 ECM that came with the engine, should i just use it instead of having the 4.8 ECM custom tuned.
saves me 300.00 to 400.00
Max
Mile High
Denver
Better to have a tune you may have to since that motor/ecu combo has never been in the truck before. You'll need a crank relearn at the least, would be worth the loot to get a scan cable tune from blackbear and have justin send you a base tune to start. Would save you loot if unless you know someone with a tech II or some tuning software to do the crank relearn for you.
M
mci007
Laguna Hills, CA
I have the superchips flashpaq 2865 plugin tuner, However i dont know if it has the ability to do a crank relearn.
Max
Mile High
Denver
Nope need a tech II, HP tuners, or EFI live type tuning software.
M
mci007
Laguna Hills, CA
Will it run with the stock ECM once i get the LQ9 installed, hopefully just a reduction in power until i get BB to do a tune on the 6.0 ECM. My thought is, this is my daily driver, can i drive it to get around town until i get the new ECM tuned.
bkboatnsleds
McHenry, IL
I know the motor will start, as we started mine on the 5.3 pcm, but I didnt rev it or even put it in Drive, so I am not sure.
blueflamed03
Oklahoma
it'll run fine with the 5.3 or 4.8 computer, just tune for changes later, but doesn't need to be done before driving.
Drewphil
