2001 Tahoe Rear Pass. Window Regulator
dawgfan83
Athens, GA
Ok guys, I need a little help/advice. My rear passenger window stopped operating, of course in the down position. I removed the door panel and discovered that the cable was crimped in a couple places, had been binding inside the motor assembly, and when i opened the assembly, the grooves in the gear (bc they are plastic), are all chewed up from trying to wind the damaged cable. So, is my only option to replace the entire Regulator and motor assembly, and if so, is there any possibility that I can get out for less than about $120? Seems that's the minimum Ive found for the whole setup. Any help is greatly appreciated and welcomed.
Paul
Alex33
I checked when I had to replace mine and 120 seems about right. the fronts are the cheapies.
candyman74
arnold, mo
go to a junkyard i have been seeing more and more nbs tahoes showing up lately.
TallHoe 96 OBS
