2001 Tahoe - Driver's door lock/unlock button not working
David Staines
Columbia City, OR
I just bought a 2001 Tahoe. I removed the driver's side door latch and cleaned up the contacts to fix the dome light / radio turn off issue. While checking a couple of other things... I noticed that the lock/unlock button doesn't work on the driver's door. The remote FOB works fine. The owner mentioned that he bought a new window control module for the driver's side. I checked and all of the connections seem fine. Any thoughts?
While I'm at it... the door insert that the 7mm screw at the handle screws into is missing. Any thoughts on where to get one of these?
PNWYukon
Olympia, WA
POWER DOOR LOCKS DESCRIPTION AND OPERATION
DOOR LOCK SYSTEM COMPONENTS
The power door lock system consists of the following components:
  • The driver door module (DDM)
  • The passenger door module (PDM)
  • The body control module (BCM)
  • The driver information center (DIC)
  • The rear door lock switch
  • The door lock relay
  • The door unlock relay
  • The liftgate lock relay-utility vehicles with liftgate only
  • The reversible door lock actuators in each of the doors and liftgate
  • LOCKS 20A fuse (rear lock/unlock relay supply voltage)
  • ECC 10A fuse (liftgate lock relay supply voltage)
David Staines
David Staines
Columbia City, OR
One more that's not on that list: Lock/Rearview Mirror fuse (3A).
I noticed my mirrors didn't work this morning. Found the 3A fuse was blown and that the same fuse controlled the mirrors and the lock/unlock button. This fixed the problem.
Hodmjstone
