2000 Denali OBS wont start
First off this is my winter vehicle so it has sat since May 1st when I put it away I left 1/4 tank of fuel and stabilized let run to get stabilizer thru system
Unhooked battery (did leave in place though like have always) coated motor with WD-40 and parked under a good outdoor cover and left it
So Sunday pull battery place on maintanance tender 2 amp until today and added 5 gallons fresh fuel
Load tested battery and its good (new in Feb 2012)
Truck turns over but nothing, tried many times but starter just turns over and not even a cough or anything
So I checked fuel pressure and I have plenty (checked at valve by TB and squirts to hit the hood)
To me it seems like it is not getting any spark what could cause this
Checked all fuses i thought pertained to starting, ecm, ign etc
Is there a security system thing hear screwin me or something else you guys think I should check
Ive stored it this way for the last couple years and it always fires right up run it a couple days change the fluids and away I go for the winter
Any help is appreciated
Thanks
Thanks
