20" offset question
GaryTanner11
Hey guys, I have a leveled 2001 Yukon, and I'd like to put 20" rims on it with 33" Federal Couragia MTs. but I have no idea what offset is best for that combination. Could someone help out?
G
GaryTanner11
I'm kinda diggin the Raceline Assaults. 20x9, but the offset is 0. idk if thats a good thing or bad. I love the look of a 20 inch rim with a nice aggressive tire wrapped around it, but I don't want to have to trim a bunch. and I'd kinda like for the rims and tires to sit flush or near flush with the fender. is that possible?
gbleezy
loves to snowboard
On my 08 Tahoe, the stock 20's were a +31 offset that sat pretty flush with the fender. My 24's are a +18 offset and the front wheels stick out a bit. My guess is that those wheels with a 0 offset will stick out.
06GMC5.3L
I would try to stay close to stock offset. But anything positive to zero should work, negative and you will rub.
Sent from my iPhone using Tapatalk.
G
GaryTanner11
the stock offset on my yukon is 0 and the rims I like are 0 offset. so if I stick with 0 offset will the I should be good? will the wheels stick out a little more because its wider? Id like for it to come out to the fender or a little under
06GMC5.3L
You should be ok then. It might stick out a little bit more.
johnsonwillie199
