1997 Tahoe k1500 Shakes in 4x4
Danni3250
Hey buds! Love my k1500 Tahoe, but when in 4x4 it shakes pretty bad from the front, any1 ran into this or know whats up? on a 4inch lift kit. angle of axles is good, and only shakes in 4x4 high or low. low speeds.
Bill 1960
Testing the Limits
Check for a bent driveshaft, bad universal, worn CV. Also the front diff mount bushings. Could possibly be a bad bearing in the diff or front output shaft of the transfer case.
exp500
If nothing seems out of whack on front shaft, like U joints, lube Tcase output shaft splines. If stuck it will vibrate.
D
Danni3250
aah thanks man, just the answears i needed!
ill be sure to update.
BbearW
