1992-1998/99 SSBC Rear Disc Conversion
YUKON1999
I bought this kit from SSBC threw a dealer on here. It says 92-98 on kit but works on 99. It’s a rear disc conversion kit that replaces the rear drums and lines. The instructions lack a little information but you can manage if you have a Haynes manual and the bolts and washers should have been marked separately. If you have no problems in removing the old parts you can replace it all in about 6-8 hours with two people and if you don’t drink too much on the job. the only major problem I had was the supplied rear brake lines were 8-10 inches to long on both side and the threaded fittings were not the right ones so had to put the extra ones the kit had, on and when installed to the transfer unit above the rear diff (the little block with the line feeding from the front) they still leak a little maybe a tear drop a day so nothing to bad. The kit didn’t come with a rear diff gasket so had to get one and gear lub. Overall I am happy with the conversion they make a huge difference in braking and the E-brake works with the kit. There is also a bolt you will to remove in the distribution block and remove the spring and seal on it, then replace the bolt (very easy part).
Instructions lack picture detail and directional arrows and things like that but you can manage its just messing with brake lines are always a pain to do.
1) Kit price was $1200 I had the calipers painted black but you can get different color if you want
2) Diff gasket was $8.46
3) I used about 2 and half bottles of gear lub I think it was 80w don’t remember for sure but they were $9.98 a bottle
4) you will need a bottle of brake fluid for you will be replacing the master cylinder I only used about half the bottle but had some so don’t know price on that
5) Then there was the beer expense
Any questions just ask I have pictures on my album and I am sure there are things I forgot to say but this is my first thread
YUKON1999
YUKON1999
what ya mean by a write up
just the pics on my album is all i forgot about taking them
SunlitComet
OBS Jedi-Do Good
unknown at this time.
stop teasing me. it is frustrating to me that i did not do this when i had the chance to get it free.
YUKON1999
YUKON1999
O gotcha if I took more pics I could but didn't really but if anyone see this thread ill help them out with it, the instructions weren't that bad just could have been better
---------- Post added at 07:59 PM ---------- Previous post was at 07:45 PM ----------
Sunlit comet
Free would have been nice for this build wasn't a cheap one
DIAZ
I just did my ssbc brake conversion on Friday. Overall came out great, BUT I don't think it makes a difference in stopping power. I still feel it the same.
YUKON1999
YUKON1999
I know this is gonna sound stupid but did you bleed all the brakes
DIAZ
I did BUT I have a hydro-boost conversion on my yukon and I already have an awesome stopping power, doing the conversion didn't make that much of a difference. Now if I had a power booster that would be a different story.
SunlitComet
OBS Jedi-Do Good
the nbs helps a bit when you put the conversion in and help to reduce the spongy brake feel. problem is the booster hole needs to be machine wide to accept the mc. a bit tricky to make it work but it does.
YUKON1999
YUKON1999
How hard of install was the hydro-boost system cuz I want to do that next
DIAZ-does your brake lines leak in that little transfer unit above the rear diff?
DIAZ
Install isn't that bad as long as you have all the right parts. My bolt it right up, but since my hydro-boost came off a vortec motor the bracket to the power steering pump had to be swapped, which is why it took longer. You will definitly feel a difference. And no I don't have a leak on mine.
YUKON1999
YUKON1999
how much did you pay for the hydro-boost system if you dont mind me asking and did you do a big brake upgrade up front?
YUKON1999
YUKON1999
just trying to get my ride to where i want it but it seems like that never ends
cuz ill see something someone else did to theres and i like it and want to do it to mine
DIAZ
I didn't pay anything for my hydro-boost, and I didn't do a big brake upgrade on the front. I'm thinking of getting the ssbc front calipers but not in a rush on that.
CliffB
