07 Tahoe upgrade to a Clifford 5904x aftermarket alarm, what bypass is needed??
07 Tahoe
Texas
Hello all! I am sorry if this is being repeated but I searched and couldn't find anything for this alarm, Clifford 5904x and what bypass module to use.
I have read on other sites that the XK06 will do the trick then others say DEI 1701g and some other module is needed.
I do have factory remote start with all the options, heated seats, power lift gate, etc...I am just not sure what will or will not work. Any help would be much appreciated.
iCalvin
California
DB-All bypass is what you need. If your buying it off the Internet keep in mind you need to buy the flashing module. I have the Python 574 which is basically the same as the Clifford 5904 just without the colored screen.
07 Tahoe
Texas
I appreciate that!! The Flashing Module, is that to write the code, the bitwriter? Or something totally different
iCalvin
California
As an Amazon Associate we earn from qualifying purchases.
07 Tahoe
Texas
iCalvin
California
Again, I appreciate that. Will installing this keep the factory settings when the after market alarm is installed, adjust the a/c/heat accordingly, turn on defrost, heated seats, etc.?
What factory settings are you talking about in particular?
I cannot answer the defrost/heated seats question as I do not have heated seats. However there is mention of heated seats in the flashing process of the DB-All. The aftermarket remote start works differentally than the OEM, the aftermarket one turns on the radio or basically everything as if the truck has its keys in, if you press the brake with the aftermarket the truck will shut off.
There are some settings you have to do with the alarm itself to get it to work properly. Such as setting it in automatic transmission mode and virtual tach. You also need to purchase the RF-loop in order for the remote start to work. Everything is pretty simple, just take your time. On the xpresskit website you can find the wiring diagram for the GM6 flash for the DB-all. Let me know if you have any questions about it, mine as well share the "problems" I encountered to help others out.
Poppyj
