05 Yukon blower keeps running
rthacker
2005 Yukon SLT, a/c fan keeps running after engine is off, key removed and door opened. The only way I could get it to stop was by removing fuse under the hood. Also the fan speed does not adjust at the controller.
PNWYukon
Olympia, WA
Check your blower motor resistor unit. Should be under the glove box area. Apparently, the relay goes bad in side the module. Something like these here at RockAuto, could be your solution.
JonnyTahoe
Minneapolis
The rear blower ?
CKendrick
