chauncey0337
I have no idea if this might help but do some research on a latch relay. I was reading about it and thought it might be worth looking into.
Im pretty sure it will happen on all of them. What are the odds of it happenning on mine and tahoewhat's tahoes, but then again it might be just us two !!!!!! XD LOL.
Latch relay, just in general or like our hatch relay.
maybe angel or chris know better.
Can either Angel or Mike let me know what relay you are using, whether brand and/or specs of it would be useful!! I think I know what relay you need to be using but curious on what you guys have now to compare it to! I also think I have figured out how to prevent that 'sleep mode' which you guys may not like too much!! lol
---------- Post added at 07:04 AM ---------- Previous post was at 06:46 AM ----------
Also, if one of you could let me know what the voltage is at one of the sockets when the buzzing starts to when the buzzing stops (the range of voltage), that would be helpful as well!!![]()
sorry bout the wait riviera racing, im using a regular SPDT (Single Pole Double Through) Relay. I think the brand is bosch but not sure. Tahoewhat should be using the same relay. And please let us know bout that solution you found for the "sleep mode" thing. I have just been lazy on bring that roof console back down to retest the voltages. LOL. but ill overcome my laziness and do it tonight.
If you get a chance Mike, post up a pic of the relay you are currently using for your setup so I know exactly what you are working with now!! If I can't find a better relay for your setup, you could always just relocate the relay you are using to either in the engine compartment or somewhere away from the drivers seat to hide the noise! Just an idea!!
Does anybody know if you get this voltage drop with the incandescent bulbs too?
---------- Post added at 06:38 PM ---------- Previous post was at 06:29 PM ----------
Not sure if this would work but what if you splice into the wire that feeds 12v to the dimmer and use that to feed the domes? Wouldn't that give you constant 12v when you push the dome switches? I would try it but mines a 2000.
I'm thinking you don't even need the relay, all you would need to do is run a separate 12v wire and a diode to each light at their switch (on the backside of the switch) and that would solve your guys problems with the manual switch dimming problem!! My map lights would never come on with the doors open so I ran a power wire from another light that came on when the door opened and put a diode on it to prevent backfeed and that solved my problem!! I'm thinking that would be the ticket for you guys, you should be able to ditch the relay all together!
