03 gmc has a bad battery drain
chad0202
I changed out the main drivers door module on my 03 gmc yukon slt 5.3 and ever since then I have had a bad battery drainage problem. I changed the battery and the altenator and it is still draining. When I do charge it enough to drive it shuts off every time I stop. I tried to hook it up to a computer to get codes but I couldn't get that to work. It's driving me crazy. It ran great until I changed that module, I even tried putting the old one back on. Any advice would help tremendously.
Fless
Super Moderator
Elev 5,280
Tell us more about the circumstances of the new parasitic draw -- what other work was done around the time of the DDM replacement and when you noticed the issue?
Is the replacement DDM GM OE, used, or aftermarket?
strutaeng
Dallas, Texas
Probably just coincidence about the door module... especially because you mentioned you swapped the old module back and no change.
You need to properly diagnose this. Watch a few videos on parasitic drain. South Main Auto has some good ones...
Welcome to the Forum from NH.
Pics of the truck, please.
You are already receiving clarifying questions and suggestions from the knowledgeable folks on this Forum.
I think that your comment regarding getting into the back and having someone on the outside spray water on the truck with a garden hose warrants a try.
Bori007
