01 2wd tahoe with bad swaying problems
Johnj1231
athens, ga
I have a 2001 tahoe LT with a 6 inch fabtech lift, I bought the truck this way, it has 18 inch wheels with 325/65/18 tires and it sways really bad when I hit a dip in the road I have checked everything, need help I don't know where else to turn
mattluttrell
I would check your sway bars. Sorry if this is obvious.
They may have left them disconnected instead of buying longer links.
tsb09000
Thread Killer
You might try getting under it and having somebody bounce on the rear bumper. Mine did something similar and it ended up being a rear trailing arm bolt hole that had become oblong. Drilled it out a little and put in a bigger bolt and all was well.
Johnj1231
Johnj1231
athens, ga
Thanks for the help guys, it ended up being the drop down bracket for my panhard bar the bolts had broke off and it was moving back and forth causing the sway
Drewphil
