- Joined
- Oct 15, 2024
- Posts
- 53
- Reaction score
- 68
Hi all,
My 2011 Denali XL AWD is having some issues, and I believe its converter shudder.
-vibrates and rpms fluctuate by about 200 every time.
-only happens cold.
-only happens in higher gears, 5th and 6th.
-Trans itself is still very smooth shifting.
Here's where I'm looking for information:
-this sounds like textbook converter shudder, correct?
-truck is 15 years old and lives in western New York. It's getting pretty crispy with rust. Probably not worth putting a new trans into, but very worth putting a new converter into and doing a fluid and filter exchange.
-needs a rear main seal while im in there.
-good idea to "flip the pill" while its out to help with cooling?
-looking at the VEGE HD torque converter from summit racing. Anyone used it before?
-what are some other "while you're in there" tasks I should look at doing?
-I've only ever pulled a trans on rwd cars. Anything I need to know about an AWD pull? Can I keep the transfer case attached? Any fluid exchanges I should do the Tcase?
Any help would be appreciated. I've done a bunch of reading on here, and I think I have a solid plan that fits my circumstances, but I'd love some outside input from folks that have seen it/done it.
Thank you!
-only happens cold.
Thank you!
