Bumping sensation
Dispointed
Just had 2014 ltz trans complete rebuild.recently had a bump while at complete stop engine idling.Similar to being bumped at rear by another vehicle.After have experienced periodically.Transmission rechecked shows no codes ,only O2 sensor code . Any insight as 3 qualified mechanics can not I D 103 k mi
NickTransmissions
Sin City
The transmission bench
Normal. My 6L80 in my 2009 Sierra does the same thing on occasion...It occurs when I tap the throttle then immediately let off and brake when coming to a stop. If it begins to happen more frequently or other symptoms begin to present, contact your builder or company that performed the rebuild work for recommended next steps, including potential warranty claim.
Gearz
The splines in the slip yoke may be worn out. You would have to change the yoke at the transmission or transfer case 4x4 and a new u-joint. This would happen on the older GMT800 trucks so they came out with a nickel plated splines. I would also change the T-Case fluid at the same time.
Chughart
i get the same thump and i have changed the front diff mounts, trans mount, engine mounts, rear u-joints, "greased" the splines on the drive shaft, have changed all the fluids, and i still get the thump. my next random repairs will be rebuild front diff, rear diff and transfer case but kind of 2 birds with one stone, regearing diffs and figured id freshen everything up while im there.
if you find a solution i would love to hear it cause the thump drives me nuts.
BadDaddy2003
