Exhaust noise
Mk-Denali
Hi everyone, has anyone noticed a spinning noise when you slow down and come to a stop. There is a YouTube video showing this exact noise. I have 2023 Yukon Denali Ultimate with 6.2L.
At 0.45-0.50s, if you listen carefully, you’ll hear this sound in this YouTube!
I appreciate you guys
Thanks
GTPace500
That's the bulletin about the issue. Long story short: the noise is "normal."
What it is really: the exhaust valve (flap) for the AFM/DFM during idle gearing. It sucks that a $90k truck makes this sound, but nothing we can do about it. Install the AFM/DFM delete (from Range) and just drive the car. My recommendation? Get an extended warranty from thompsonauto.net or James black cadillac. I think I spent about 2400 on mine and i'm covered bump to bump until 100k miles/2031
KMeloney
I'd call it more of a "jingle" than a "spinning sound" -- but yeah, I notice it on mine, too (and it's what's been described above).
Anomaly
My opinion of two noises I heard:
1st noise at ~0:23s sounded like it was the starter motor and/or solenoid.
2nd noise at ~0:45s sounds a little like brake pad engagement on the rotor.
Maybe the noise sounds different in person and it is possible that it is the exhaust valve/flap.
pronstar
DFW
The flapper on our 2018 recently failed, it rattled pretty bad on startup.
I just had the shop remove it entirely.
You want to retain the flapper if AFM/DOD is active on your truck
1948Buickroadie
