2007 Denali after turned doesn't recognize the door has been opened and battery dies
dshoblo
Hi all,
My 2007 Yukon Denali after being turned off doesn't recognize the driver door has been opened, so radio etc. stay on until the battery dies has anyone had this or know where I should start on this?
Thank you
Moderator
People's Republic of Colorado
Use a scanner to look at the live data; there is likely a PID that shows the status of the driver's door.
Does the radio shut off when opening any other door? It's only the driver's door that doesn't report as open?
D
dshoblo
Other doors do not affect the radio just the driver's door. I think it's always been this way. Ran a scanner and driver door module had 18 codes but they passed at this time even though the problem remains.
Moderator
I would venture a guess that the driver door latch is not reporting as being unlocked. The Driver Door Module is the switch panel in the door card.
Wonder if there are any bidirectional tests in the scanner, for the latch?
Tupapi
