LordWayback
- Joined
- Jun 23, 2022
- Posts
- 512
- Reaction score
- 399
So I have a skar ix8 I’ve been running with bushings as spacers because it’s too tall for the box , so what I’m gonna do is make a riser plate with Home Depot pieces and make a tutorial page for anyone who wants to use a taller 8” sub. which greatly expands our subwoofer options because we can run tall 8” subs or slightly larger OD than 8” subs (in theory) the skar IX-8 is Over 8” in OD but it’s gonna seal with the box with my adapter. Before pic I’ll post a After pic tonight with details I’m hoping to make the adapter around $20 in materials (excluding drill because every single household should have Atleast one) my drill used was $7 and our ryobi was $70 I’m using my old school aluminum $7 black and decker in this project. : I’ll post exact measurements so you can replicate it with this. when purchased this was a $40 sub and factory components + spacer also more details to eliminate trunk rattle (minus trunk glass that hinges). when you upgrade to a larger sub. This thing already bangs on a cheap stereo that only works 50% of the time I shall go back to a JVC double din soon or delete the factory amplifier because the factory one cuts out and causes the issue I believe, it’s not the fuse.
