2002 Yukon, 140k miles, Fixing up over time
T
tgui
Didn't have a ton of confidence on the test drive.
T
tgui
This second rebuild gave me the chance to put in a nice flex plate!
You can measure clearance with a drill bit. 1/8 inch on the dot.
T
tgui
The HF cheap trans jack is great for all sorts of things.
jcevans7
Friendswood, TX
I had to put my kids down for bed and grab popcorn. As I started trolling. I couldn't stop myself from going down this rabbit hole. I know my Denali will need the front diff redone at one point. Thanks for sharing all of this. Keep it up and good luck.
Sent from my SM-N910T using Tapatalk
T
tgui
My pleasure! This place and performancetrucks.net are great resources.
T
tgui
Details are that I'm an idiot as to why the speedometer isn't working.
Wrong connection under xfer case vss extension. I haven't had time to test but feel its probably this. That and it's closing in on 15F and my garage isn't super insulated.
Purple green, not purple yellow.
Also, tests can be in on pcm red connector pins 20 and 21.
Note that xfer vss resistance is about 1600 ohms.
Like this.
T
tgui
Bad news, no shifting, P1860 code, need to research.
Good news, speedo works!!!
T
tgui
I got rid of all codes and fixed more wiring.
I still am stuck in 2nd. Either I have a bad pump or bad valve body.
I had the tool to test trans pressure!
It came broken.
T
tgui
Here is the problem. I botched the AFL Sonnax kit somehow. Its entirely stuck. This causes problems!
It might have also caused burnt up frictions. I'll still try to drive it and hope that it will last until spring when its not cold and ******.
New valve body came this morning. I hope to have everything back together this weekend.
T
tgui
Neat, new one has all new solenoids and comes complete and assbled with valves :)
Not bad for $110
T
tgui
VB pictured above was defective. God damnit.
T
tgui
Finally got a new valve body and put it in the trans. I only had a little bit of time but got the truck to start on stands.
T
tgui
I did some logging on stands. I logged requested gear and calculated ratio based on input and output speed sensors.
I slowly went up to 70mph and saw all gears requested. 1st to second was too fast to catch the ratio, but results were.
2nd, calc ratio 1.47
3rd, calc ratio 1.0
4th, calc ratio .78
70mph was around 2000rpm, which sounds sane for 4th.
A friend wants me to full throttle on stands. **** that. The truck is pointed at the middle of my house.
It's rainy, cold and may snow soon. I'm too delicate of a flower to break down in this shit. I'll take her out later :)
Also gotta say the part throttle shifting was damn smooth. I've got my hopes up.
T
tgui
My AC started only blowing hot air. AC still worked in the rear. Turns out I had a bad actuator. Got a new one from Amazon, but still had problems. Turns out you have to let them calibrate. Here is was I did.
Turn all AC off and heat to coldest temp
Disconnect neg battery
Connect battery
Get in truck, close door
Turn ignition on but don't start motor
Wait a couple minutes and listen to your actuator chirping. I felt it moving. It's discovering the bounds of the blender and can take a while.
Start engine and go for a drive to get heat in the system for easier testing.
Park, engine off, open and close door. Supposedly door open and close ends a cycle, what that means I don't know.
Start truck and test! Mine worked at this point.
This thing under passenger dash near center console.
canadiandux
