Pics-biggest tires on stock suspension
Shorty
I am getting new tires and maybe wheels for my Tahoe. I wanna see what the bigger tires look like and hear your opinions on what sizes will fit under the stock suspension. I want to keep stock wheels and suspension and fill that wheel Gap. I want to go with a 32 inch tire or a 285. I also want them to be a little wider with no problems. Not too wide but wider than the 265/70/17's what is taller and wider that will fit a stock truck? Also I wanna see some pics of your stock Tahoes with your bigger tires. I am also new here and my name is miles. I live in Athens Ga:Handshake:
vatahoelt
NoVa
285s are going to be pretty close to the biggest you can go without some kind of modifications. might be able to fit a 295 in there with a little rubbing.
S
Shorty
Yeah I want to go a little wider too. I know nothing about tires. I juust wanna know what sizes would be little taller and wider to make this HOE A little more stout looking.
DenaliAK
Colder than you
Alaska
Any bigger on stock suspension and you will rub on corners.
Simple as that.
And for that reason, you will probably not get any pictures of bigger tires on stock suspension....lol.
S
Shorty
ok so sizes...........32.11.50 .17too big?
32.10.50.17
285.75.?
DenaliAK
Colder than you
Alaska
My summer tires are 285/75/20's. If I turn the wheel all the way and get any nose-dive on a turn, it rubs. Otherwise it's fine. The tires new measured out at 32 inches with a tape, although they are now somewhere between 31-32".
Nickleahy23
Portage/Menomonie, WI
i run a 295/35/24 which is 32.6" tall and im lowered 3/5 and i dont get any rubbing...
you can probably run a 285 at the max...that would take a little cranking of the front, and maybe some small trimming...but people do it all the time
S
Shorty
What about width ? I want my tires to at least come out flush but not stick out what or how would I do that?
Eagle
Thansk for all the help -STAFF!
EL PASO, TX
I've got 305/45/22s, ie a 33" tire...
but my hoe has factory flares.
Shot of general fitment
Better overall shot?
Full Lock and off camber (ie out of driveway) it barely kisses the liner on just one side.
Just enough to wipe the dirt away.
DenaliAK
Colder than you
Alaska
Hmmm....I'm gonna have to write down that size, Eagle. I like the way they fill the fender.
S
Shorty
Nice Maybe I will put a set of 33 inch tires on and call it a day
vatahoelt
NoVa
i'm probably going to go with a 285/70/17 when i go to get new tires within the next month or so.
S
Shorty
I am lookig to keep stock 17s right now but will go bigger later. what sizes do they make in a 17?
DenaliAK
Colder than you
Alaska
Looks good, Tribal. Next time I get summer tires I'll be looking for that size on 20's. Thanks for the pics.
6point2lovelifers
