Is autoride worth keeping?
mazdawg(Mikey)
HGIC(head ginger in charge)
Lancaster SC
So the wife's 08 LTZ came with the autoride of course. After we bought it I noticed that the rear shocks were blown all to shit. I swapped them for some oem 06 shocks we had from a buddies Yukon to get me by because the truck had some weird swaying when hitting bumps. I never heard the compressor kick on so I'm assuming the previous owner pulled the fuse possibly? Anyway I want to lower it possibly 3-4 and I'm wondering if I should buy new air shocks for the rear to make the autoride work again and then lower from there or should I pull the air stuff and start over with new non air parts and lower it that way. Any input guys?
ulakovic22
Argyle, TX
I think if you are going to drop it at least 4 then ditch the autoride. The max I plan on going is 4" so I'm just going to do shock extenders and utilize the autoride to level out heavy loads versus using helper bags in the springs.
Ben
PCB, FL
So if the shocks were blown the compressor is most likely bad too.... Because once the bags on the shocks go the compressor is just going to run constantly because its going to sense being too low. With that compressor running all the time its going to go bad fairly quickly. Mine did the same and I replaced both the shocks and the compressor; I'm currently running with the fuse pulled because I'm lowered and running airlift helper bags in my rear coils but if and when I ever go to sell or go back to stock height for any reason I just reinstall the fuse and I'm good to go.
Deephaven
Wondering the same, mine is lowered and my autoride just took a dump.
I just want what rides the best from a handling perspective without ridiculous negatives on the ride.
Seems the three options are:
$$$ GM replacement parts to have an adjustable ride along with load levelling. Not that I've ever been in a car where the sport/comfort suspension settings made a difference.
$$ Arnott replacement kit with only auto-level
$ Belltech replacement shocks with no level or ride control
My tendency is to believe a real shock is what would actually give the best overall performance along with a more than reasonable ride....but don't know if the Belltech's fit that bill or if the other options are still superior.
mazdawg(Mikey)
mazdawg(Mikey)
Lancaster SC
So what you're saying is if my fuse is out and I put it in and the compressor kicks in then Im good to replace the air shocks. If the fuse is still there or if the fuse is out and I replace it and the compressor doesn't kick on then I'm ******. Would the "service suspension system" being on cause the compressor not to kick on?
Ben
PCB, FL
Just because you hear the compressor running doesn't necessarily mean it's good. But making noise at all is better than none. Typically you can look under and see if the shock bags are ripped or torn. My truck never did the service ride control until I messed with the level sensor arms. One of yours may have been disconnected causing the code. Replace the shocks if you know they are bad and if they fill up with your current compressor you should be ok.
mazdawg(Mikey)
mazdawg(Mikey)
Lancaster SC
The bags were torn so I removed them and went with a normal set of shocks because I thought it would make it ride less ******. It had a bad sway to it
Deephaven
How do you feel it rides compared to stock?
mazdawg(Mikey)
mazdawg(Mikey)
Lancaster SC
I'm not sure the before because it rode like ass when we got it. We've only had it for a few weeks. I replaced the front sway bar end links and the rear shocks and it rides fine now
ulakovic22
Argyle, TX
Personally I would replace with factory stuff. The autoride rides good and the load leveling is a plus so you don't have to do it manually. I have a set of rear shocks NIB if you want to buy them. PM me your number and I can text you pictures. AC Delco number is 580-358 and the GM number is 25979392.
Deephaven
Doh, about an hour after I ordered some from Amazon.
$900 or so for all 4, a dryer and compressor. You all talked me into the better ride and once I realized I could get the shocks for $175 a corner I figured the little bit extra wasn't so bad.
t.stimpson
personally I liked the factory autoride way better. My 04 denali had blown shocks and non working compressor so I swapped it all for bilstien package and hated it. Very rough and bumpy ride unlike the smooth soft ride from the factory. My 09 denali was the same when I bought it so replaced the the factory shocks and compressor from amazon cost $1000 and love the ride.
Durobans
