HID Hype
dpate8516
Ok so newbie to this forum but not to forums, but what is all the hype over HID kits for the Yukons? I have read the threads and done research.
To me it seems that the vLED 9005 for headlights would be the best option.
I have installed HID kits in my last 2 vehicles (Cadillac STS, and Acura MDX) and have experienced all the problems from relays to misfires.
Talking with my local tech here in Texas, there shop wont even installl HID kits anymore due to the issues and time constraints they pose when owners bring there vehicles back to get fixed or looked at.
The kicker for me was when the owner of the shop, who just purchased a 2015 Denali for his wife and 2015 Sierra for himself, takes me outside in the daytime and shows me what his plug and play vLED's (6K) look like and wow they are bright and match perfectly with the DRL's.
Heres a link what are your opinons?
http://www.vleds.com/bulb-type/headlights/9005-hb3/9005-ultra-lmz.html
https://youtu.be/xBnpLt8djI8
Of course Im going to go with them for my fogs, reverse and license plate, but Im asking about headlights specifically.
The projector only pushes out or in for high and low beams and worked well in his truck with the vLED's.
NathanJax
Vacation Nathan
Jax, Fl
The main problem is your still not putting the correct bulb in the correct housing. There's a reason all LED headlight vehicles have multiple projectors in them.
dpate8516
dpate8516
The vLED's I plan on purchasing sit inside the housing perfectly and can be adjusted.
Mondo
Watch this video.
https://youtu.be/hRqxTl4rxlg
I personally dislike LEDs cause they output the light only 180 degrees so projection and display patterns may not look right.
HID'S output in a full 360 projectin more light and much further than a LED.
BMPNUGLS
Mid-MO
The LEDs you have a link for says "not for use with housings that have dust caps"....all the new Tahoes, Denalis, Suburbans, etc have housings with dust caps....
dpate8516
dpate8516
I'll ask my shop guy here about the housing and dust cap. I'm sure I read about the work around, but not sure if i want to drill into that.
Sent from my SM-G925P using Tapatalk
NathanJax
Vacation Nathan
Jax, Fl
regardless your current housing isn't made for LED lighting, let alone that specific bulb with that light output pattern. No matter how far in our out you put the bulb, housings are meant for a specific bulb. Will you get light output out of it, yes. But it's not going to be a good pattern, or correct pattern. Here's the thread for the 07-14 with a bunch of good info and links in the first post. There's not one yet in the 15+ section, but it seems like there's a decent cutoff and light output in the 15+ halogen based housing if you put an HID bulb in there
http://www.tahoeyukonforum.com/forum/showthread.php?t=45797
dpate8516
dpate8516
Thanks I will check out that thread.
I’m not against HID as I am a recovering HID addict.
After my last HID anonymous meeting, I decided to get a feel for the LED bulbs. I guess the main issue is whether I care about the correct light output and some minor aesthetic differences.
Update:
Here is the H11 light just for comparison.
http://www.vleds.com/bulb-type/headlights/h11-h8-h9/h11-ultra-lmz.html#reviews
JBmore
Don't waste your time with other bulbs, that's what I did. I tried at least 8 different bulbs and the output was never good enough. Got the HID kit from xenon depot with Philips 4300k bulbs and they have performed flawlessly for a year now. Not one issue or flicker. I didn't want to go this route, but I had no choice and am now glad I did. I think they are brighter than the stock HID's on the Denali.
dpate8516
dpate8516
Thanks for the great input from everyone. I think I'm going to hop on the HID bandwagon.
I really appreciate the knowledge shared through this venue. Can't get this from bias view points of shop owners.
NathanJax
Vacation Nathan
Jax, Fl
I tried to get some bulbs from a local guy here (SHOULD be easier) and he was an idiot. I argued with him for 5 minutes before just walking out.... :(
Would have been easier to get local (and just a little more expensive) than ordering online and waiting to be shipped.
bourgeois
Did you install the relay harness and canbus harness for the kit? Or did you just use the factory headlight plugs? Thanks
ezdaar
Chat Troll
Redneck central, Aka Houston
Always use the reteofit source relay harnes. It is by far the best avalible.
Even on 35watt kits.
Warm up time is reduces and all flicker is gone.
JBmore
The kit had capacitors and relays. Been working flawlessly for over a year.
Kcrowe79
