EXPERIENCED HELP NEEDED!!! fuel injector fine tuning
t_ahan
Crofton, Md
need some input and advice to start addressing the much needed fuel system upgrades...
so i am looking to get new injectors and a fuel pump (if necessary since mine my oe still has not burned out)
When i did my build i knew injectors would be needed but with my light/break-in feeler tune i was 75% duty cycle. Earlier this summer i finally got a BB Tune in person by Justin and he also confirmed i needed to do something about the injectors to get the full potential out of the set up. Once he was done tweaking we were at i think 95% duty cycle(maybe 99%,i 4get) either way i am maxed out on fuel delivery and maybe supply.
options so far:
47# part# M-9593-G302 (ford injectors???)
46# part# 30462-8 (FAST)\
44# part# 32D-00-0044-8 (deatsch werks)
30# part# DFP-FJ10494 (stock delphi chevy 8.1L injectors)
of course the re-tune, then i need to figure out what fuel pump to use!
b4 i contact BB i thought i would get some input since i am undecided:emotions133:
any advice/opinions/experience would be greatly appreciated!
thanks every1
Build Set Up:
'03 LQ4 .030" over bore with Wiseco forged pistons, stock length eagle forged I beam rods, melling hv oil pump, cloyes billet timing chain 3bolt, arp rod bolts, arp main and head studs, 0.000 deck gm 243 heads , comp valve springs, comp cam-xfi rpm cam [email protected] intk216 exh220, comp lifters, comp hitec push rods7.4"length, comp ultra gold arc series 1.72 ratio rockers, fast lsxrt 102mm intake manifold, fast fuel rails, aeromotive fuel pressure regulator, bbk80mm tb, k&n cai, bbk shorty headers, magnaflow cats and back, and preformabuilt level2/heavy hauler transmission with a 2500stall tq conv, BB Tune
JennaBear
Resident Ninja
San Diego, CA
The Delphi 8.1L are large enough for your needs, and there is plenty of data on them to make them plug and play for your application.
ezdaar
Chat Troll
Redneck central, Aka Houston
Why are you running a 102 fast with a 80mm TB? Choked off much? Yup. Atleast get a 90, better yet a eBay 100.
That cam, heads, intake with a 2500 verter?
What's comp ratio? Did you go up any with Pistons? Since you didn't cut the heads of you didn't, you actually dropped compression with that combo.
Are you building for a turbo?
You have a 2-6k cam with a 3-7500k heads and intake combo along with a 2500 verter.
Mis matched system to say the least bud.
You would be better off with a nnbs intake port matched to a ported oem TB with your combo. It would make waaayyy more power below 4k and be very close above.
Toss that 2500 verter for a tight 3k or 3200. With the right verter so will still be able to tow np, if needed.
Give yea props for the effort and high quality parts, but the combo is way off.
t_ahan
t_ahan
Crofton, Md
i was hoping u would chime in !! yeh i will probably do the 8.1L since you will be doing the tuning! Justin had mentioned that he already has the specs for them to add them to my tune file. it seems that would be easiest route.
now as far as fuel pump goes do u think i need to plan for that?
jough
Arkansas
Another injector option are the ones from a 5.3 Flex Fuel motor. I understand that they are 33 lb/hr. You should be able to find them for a reasonable price.
The 6.0 injectors are 25 lb/hr, which is the same as non-flex fuel 4.8 & 5.3 motors.
My engine swapper re-used the whole intake assembly from the 5.3 Flex when he installed my 6.0 **. Black Bear took that into account when doing my tune.
t_ahan
t_ahan
Crofton, Md
i apologize if i came off wrong. and gave the impression that i know exactly what i am doing.
i will give alil intro of my self to the community since i dont think have really ever formally done that and am now seeking the help of the vets here!
i was looking for this kind of feed back! good stuff here!
i am fairly new to the aftermarket for what these motors can actually do with the right parts. i seem to be learning as i try on my own cuz no1 i know is doing them yet!? they havent been bitten by the LSitch! they are still stuck in the 350sbc ways. i have been reading the LS books to further my knowledge and my understanding of these motors. but most are for swapping and not really vehicle specific( wish i had a book for gm fullsizes) there is alot to learn about these big beasts!
my set up was purely a- "lets see what all this free stuff can do!"
the build combo and my LS curiosity/addiction started with ....
after automotive school i worked at a few shops-back in '05 &being the young 18yr old gear head trying learn how to make em so i could break em! i worked under all the old school guys that didnt care about anything other than making a paycheck. they taught me how to diagnose/fix/repair and everything else needed to succeed in the business.in 07 i got the opportunity to fill in for the service writer. after that i became manager/mechanic/safety&emissions inspector!
i started working on faster and cooler cars but nothing really built, it was all rich people bought cars. lambos, ferrari, bugatti, what would be expected in that zip code the shop was in. it was fun and all but i could never afford to play in that scene. the vettes and mustangs that we did have were like procharged, custom bolt on's with lambo doors and rich wheels. whatever auction my customers bought their cars from, didnt tell them why the awesome car was being sold in the 1st place. but the rich people dont care as long as it looks good i guess they buy it and figure a motor is cheap!
that worked out great for me!!! over time i ended up with the top end for an LS motor!
late '07 still young and dumb(i feel i still am!lol) kid coming in '08 and the wifey wouldnt let me get 06 z06(always loved that car and it was kind of my intro to the LS world), she wouldnt let me get anything LS worthy. the best i could get her approval on that wasnt a honda, toyota, lexus, benz, bmw (+all other out of budget cars!) the gmt800's she said fine! so i found my '03denali and said...
so lets see what would happen to throw what i got together on the denali!?? so one by one i started adding the parts starting with the simple blot on's and then 80k miles happened and it came time for transmission. at that point i had the heads still sitting on my tool box and decided to pull the motor n put the heads on to finish the parts pile!
once the heads were off and the trans out i knew a factory rebuild with vette servo and shift kit wouldnt last long with the way i planned to push this motor. so i called preformabuilt and told them the motor specs and they recommended what i got so thats how i ended up with the 2500 stall.
b4 the block went to the machine shop i ended up buying some pistons since so far i havent paid for much. Being dumb and getting pistons delivered to the shop on a friday! Well my wonderful(not anymore) friend thought he would help me out and assembly the bottom end over the weekend!!! Monday i came in to find the not so bare short block ready to go to the machine shop and my boy saying "isnt that beautiful!!!??" omg nothing mic'd out and the free handed sloppy hone job, wtf! he put it together like it was just some nuts and bolts.
i put it together anyways since like one year had passed since the trans went and only had 1st n R ! i couldnt wait to drive my truck ! WELL after many many hard runs i was actually amazed with the set up!(machinist said they always feel strong b4 they blow up lol). i fried a few pistons(i tuned with a diablo predator:chair:)+lost compression in 6 cyl(good stuff when you find piston rings in the cats!)
i moved states, switched careers(no more garage)pulled the motor outside :( and sent it out for the over bore. the machinist i found had an H2 and was building an 427 stroked LQ4. i had him do the long block assembly for me which turned out to be a great deal. come to find out this was his 1st LS build and he was asking me for advice and we ended up trying to figure everything out as went! he went the hptune and i went efilive, and back and forth etc. , jus having a good time learning!
i joined the forums to seek out the guys/girls that have been here and done that to help school me and pass the knowledge/experience down
during the build i always thought about doing an fi set up cuz every1 around me had boosted lil euro cars and i would be like "man if only they knew about the potential i had in the denali)lol
wow this is alot of typing...im done making excuses for my bad build lol.
the help/guidance is always greatly appreciated and absorbed
---------- Post added at 05:19 PM ---------- Previous post was at 05:11 PM ----------
Cam lobe lift: .309 intake , .313 exhaust
Duration@. 050 lift; 216intake, 220 exhaust
ezdaar
Chat Troll
no worries bud, we all start at the same place, knowing nada, and making silly mistakes.
Its all part of it.
You wouldn't believe some of the stuff I have done.
t_ahan
t_ahan
Crofton, Md
i always felt the bottom end suffered but blamed it on being a big heavy truck and not the tc or mis match set up... but wow even with the lack of fuel it has a top end that loves to pull deep into the deadly mph range. the truck is great for hwy pulls! but thats all lol
so it sounds like its safe to say that i am not spreading the power out evenly through the board?and could gain in more than a few area's?
01ssreda4
This is by far and away THE dumbest thing ive read all day. Wow.:wtf:
jough
Arkansas
Why 243 heads on a 6.0 Lq4? I understand that is not a good combo. 243s would work great on a 4.8 or 5.3, but not so much on the 6.0 due to the bore size on the 6.0 versus the chamber on the 243 heads. I think it would raise your compression ratio, maybe too much.
ezdaar
Chat Troll
243's are great heads, even on a 6.0. But they do in fact drop compression.
This is why everyone cuts them 30-40 thousandths, to bring compression back up.
01ssreda4
Not on an LQ4 they dont. LQ4s (which is what he specifically cited) came with 317s which have bigger chambers then 243s. Adding even LS1 241 heads have more compression then 317s, the largest chamber of all the gen3/4 heads.
317s = 72cc
241/853 = 67
799/243 = 64
806 (or whatever those junk things are numbered) = 62 or 1
That's just off the top of my head to give you an idea. The old 5.3 heads are ******* junk and flow the worst of any Gen3/4 head.
01ssreda4
Though this appears choked, lots of your gain comes from plenum volume, which the 102 has plenty of. Its the same reason the old FAST 78s showed gains on LS1s. While the above setup is not optimal, its still ok, and definitely fine for a truck.
You do remember this is a truck right? Much bigger then this and you are pissing all your towing capabilities away. This combo may have a little bit of a mediocre midrange but it wont be worse then stock and it will still love to rev.
LQ4s came with 317 heads which are about 72cc chambers, he went to stock 243s which are about 64cc. His compression is up quite a bit over stock
Only in your mind fella.
Wow, how about no. Stop making up numbers. Fast and stock style intakes don't flow good to 7k, I don't care what heads you've got. Unless you're throwing a Victor Jr/Super on there with a 4150TB you aint making no power at 7500.
While I agree the NNBS intake would have been the cheaper route, it would not have made more power. The Fast intakes generally give up nothing anywhere in the powerband. Now it might not gain everywhere, but it definitely isn't losing anything.
Tow how much though? You don't know his wants or needs so that's a loose assumption. I personally wouldn't build a truck to go fast (seems counter-productive to me) but if I did it wouldn't get a 2500 or a 3200 and it wouldn't be able to tow when I got done either. He may have gotten a good deal on it whole knows. Maybe he doesn't wanna pull it at this point. I don't necessarily think its completely justified at this point.
Hey, No:chair:
My thoughts are in BOLD. You asked, so there it is.
You have just enough knowledge to be dangerous. You've done some reading, but not near enough. You don't know basic powerbands, basic specifications of stock parts. If you can't keep up with all that maybe you shouldn't be chiming in on these types of threads. Just a thought. :kiss1:
---------- Post added at 08:22 AM ---------- Previous post was at 08:20 AM ----------
And yeah, I may have been around a while......
http://ls1tech.com/forums/member.php?u=98787
X-ray Nerd
