Need help lifting my 2001 Chevrolet Tahoe
Roselle, IL
Hi guys, I need help choosing what I want to go with. I don't want to go to big of a lift because I still wanna park in my garage but I want some height and some stance. If you guys could help me that would be great? I'm not doing anything until spring just because working outside on a Tahoe in the cold is one of the worst things someone can do!
TheAutumnWind
Figure out how much clearance for your garage you have. 3/2" lift would be nice and allow for a decent sized tire.
sparkie94
I got a 01 Yukon and just did keys and it fits 35s no rub has 33s and 22s in pic
COUNTRY_BOY_TILL_DEATH
Roselle, IL
Yea Im going to do a 3 in body lift here soon
I would love to after the 2 inch leveling kit but I don't think it would fit in my garage. But then again I'm looking in to buying a 1979 Trans Am or a 1st generation Camaro so I could put the body kit on and just keep it outside.
owl_93
Go with new coils, spacers, shocks, and keys. My 33" MTs clear with no rubbing other than if I have the wheels turned all the way and I'm backing up.
Roselle, IL
Thanks
Thank you but i think i'm gonna go with the 5" Premium Lift System. Which is basically just a 2 inch leveling kit and a 3 inch body lift kit. I'm kind of new to all the lifts and everything. so thank you all for all the help! And what kind of shocks should i use though? I'm assuming that the body lift doesn't increase the size/ type of shock i have to get?
Z-56 Hoe
What do I do????
Houston
Look into lift spindles and maybe a body lift over leveling keys. You will have a much better ride!
owl_93
Everyone around here myself included are Bilstein fans. When I went down to the shop, the dudes workin on my Hoe said they were glad I got the Bilsteins cause their the best you can buy. They said the only others they would recommend were KYB, but they said that all in all, Bilsteins have better, straighter welds and their the best. I wouldn't have known any better, but everyone on this forum says Bilsteins are the best so I'm glad I went with that advice.
The ride is far better than factory. Even with cranked (not all the way) keys.
Sent from my Galaxy Note 4 via Tapatalk for Android
Roselle, IL
Alright I'll have to look into that thank you.
---------- Post added at 06:14 AM ---------- Previous post was at 06:13 AM ----------
Alright I'll have to look into those. I'm probably gonna get those then just because everyone says that they are the best
01TX_Tahoe
Semper Fi
Pasadena, TX
I've got 3" spindles and 2"-2.5" spacers in the rear with Z71 coils. I don't have any problems other than the one owl listed when backing up. I'm ready to do a 3" BL real soon too.
Roselle, IL
So I've taken in what y'all have said and I've decided to go with a body lift, keys, spacers, and bilsteins. I just need help now finding what y'all recommend?
owl_93
Here is what you need...
Front shocks: Bilstein (24-186643) 5100 Series Shock Absorber https://www.amazon.com/dp/B00BYNJAVW/ref=cm_sw_r_awd_m-R-ub1HW0M01
Rear shocks: Bilstein (24-185783) 5100 Series Shock Absorber https://www.amazon.com/dp/B009FU66FO/ref=cm_sw_r_awd_baS-ub104YG2C
Coils: Moog 81069 Suspension Coil Spring https://www.amazon.com/dp/B00498ZR7A/ref=cm_sw_r_awd_YaS-ub1K4D3TH
Keys: 1" - 3" Torsion Bar Lift Keys Chevy Half Ton 6 Lug 4x4 Trucks https://www.amazon.com/dp/B00BEN1PXI/ref=cm_sw_r_awd_QbS-ub103YDWK
Spacers: 1.5" Lift Rear Axle Coil Spring Spacers Tahoe Yukon Suburban https://www.amazon.com/dp/B00BEN3BEY/ref=cm_sw_r_awd_LcS-ub0YPNVHA
As far as your BL, I have no experience or recommendations for that.
Roselle, IL
Thanks and how much lift would I get out of this setup?
---------- Post added at 04:22 PM ---------- Previous post was at 04:21 PM ----------
How much clearance do you have in your garage?
Not even enough for a 1 inch lift haha so I've just decided to have it outside sadly. I'm gonna try to put something over it when it snows and rains
owl_93
Between 2.5" - 3"
Before:
After:
Roselle, IL
Oh that's cool. And that's exactly what I want because I'm also doing a 3 inch body lift so I would have 5.5 - 6 inch lift. Thanks y'all. I'll be ordering my stuff soon!
Korbin_A
