Coil Over Conversion Installed
Tahoewhat
Tahoewhat
Ballin' on a Budget
TX
Boy I haven't updated this in quite some time.
Thus far:
I am still happy with the front setup - has not changed since the first post. Still rides decent up front. It is the rear that is causing me problems and is effecting the total ride quality of the truck.
I also have since gone through 2 sets of rims, one set 22's GM and now 24" U2 55's, that have a 35 sidewall. I must say though even with the small sidewall the quality is not that bad. At least not as much as I thought, but these will still be going away - makes my tahoe slower than it already is.
In short, still loving it, but of course still rides like a lowered Tahoe, especially this low, but not like a low rider. I believe I actually need a c-notch to help the rear, but for the front it is fine and still have no plans of switching back to tbars.
I need a place to work on it to fine tune everything and need a suspension expert with me, lol, but the space is my limitation right now.
I have started to wonder as well, if I can switch to a silverado's front setup w/ springs and shocks - change the LCA's to silverados, not the 4wd version as they are tbars. if that makes sense. maybe then i could get a heavier spring for the front. Just a thought.
Tahoewhat
Tahoewhat
Ballin' on a Budget
TX
UPDATE:
Did not forget about this thread -
Finally, yes finally tuned the front suspension and got the shock in the correct spot / halfway point. Mine has been on the lower side of the coil over - meaning instead of being at the halfway point, (which it needs to be at) mine was about 1" below the halfway point.
Did not change any firmness settings on the shock, but right after fixing the level I noticed a big difference in ride. Even with my 24's on w/ 35 sidewall. Made the ride much much more bearable w/ the 24's.
I can not stress to anyone doing this, Do what atomic says and put the shock / coil over on the halfway point and leave it there so the rebound and travel is at the right point and not bottoming out all the time. Your ride will thank you. Wish I would have had the time to fix this along time ago.
And truck is level still as well. Back is actually a little lower than the front, now. But not eye noticeable.
( will say was about to give up on the ride of this, but now that its right, the ride is better and going to keep it up and change to smaller rims and see how it goes from there. But with just the fix, It made quite the difference. )
Bomba02
Thats great to hear! Wish i got mine right, think i had other issues tho. Whats your fender measurements up fronts?
Glad you finally had some time to show her some love. Congrats on school by the way!
Billy
Tahoewhat
Tahoewhat
Ballin' on a Budget
TX
Billy
Yeah, im not sure about yours.
Measurements - have not done yet. Will get ya some soon.
Finally had a chance to use friends lift and do it the proper way. Much better than what I have told you.
Thanks - it was a long road.
Atomic
Huntsville, AL
Glad you finally got it dialed in! Your right, it does make a big difference. If you are feeling extra froggy you could even put it 10% higher up so it leaves 60% travel for compression and 40% for extension, but I wouldnt go much more than that.
Tahoewhat
Tahoewhat
Ballin' on a Budget
TX
You know I was thinking about going a little higher. But its about even right now with the rear, so im happy.
But may of finally half way understood the spring rates, etc. B/c adjusting the coil up to halfway, it started to get tough - I could feel the spring actually getting more stiff. Should of listened to you a long time ago. (but time was not on my side then. lol)
Tonight I changed the shocks down one click after work and made the ride a little softer than yesterday. Think its about 12 clicks or so now. Going to go down to 10 tomorrow and see how it rides.
Any of you know how the other guy on PT.net truck is going?
Atomic
Huntsville, AL
Which guy? The guy that did the bushings? Last I heard he was working on other parts of his truck and he considers the coilovers done and good
Tahoewhat
Tahoewhat
Ballin' on a Budget
TX
Yeah that guy. (should of been more specific huh, lol)
Good to hear. Im going to try eventually once i get this all squared away, your bushings you sent me & other ones I have. See how they do.
Tahoewhat
Tahoewhat
Ballin' on a Budget
TX
Little update here:
Sold the 24's and got some temporary 17's w/ a bigger sidewall and adjusted the rear shocks a little softer and ride improved, even more so than my last post above. Almost forget about the ride before. Much better w/ the 17's than 24's, but looks is another thing. ha ha ha
phillipmh06
Does anybody know if the 07+ LCA's will fit the 00-06. Looking at dropping those off for less unsprung weight on a coil over set up.
Ryan Buck
Mesa Arizona
So I had one that was dumped like that back in the day and I remember one day after I did it I took it for a test ride and went to the Sonic drive-thru by my house and pulled in park ordered some food and was sitting there and then all the sudden boom the ******* torsion key fell out LOL the problem was it was so low when it was bottoming out the torsion bar walked forward until finally it fell out of the key. Scared the f out of me lol to fix it I just cut off the bump stops in the brackets and it never did it again
memphizhoe
So if you have the aftermarket lower control arms do you still need the atomic brackets ? I saw on his site where guys have not been using his upper bracket and it worked. Just curious lol.
JamesinAbilene
