Can I make mine like this?
Wrenching09
What size do you think these wheel and tires are? Do you think it's lfited or just leveled ? I want mine just like the photo attached . If anyone has one with this body style not lfited with whees and tires please show me pictures !
attachment.php
Red_Raider
Derby, Kansas
Look like 33's on 20" wheels probably 12.5" wide. As far as the lift., it's hard to tell.
W
Wrenching09
I want similar wheels with stock height just with cranked torsions. I love the fuel hostages I can't many pictures of 18s on a Tahoe or Yukon to compare
W
Wrenching09
It Is and
---------- Post added at 10:04 AM ---------- Previous post was at 10:04 AM ----------
All wheel drive
Z-56 Hoe
What do I do????
Houston
That Tahoe is sagging 2" in the rear. I wound NOT crank T bars up all the way it will ride like crap!!!! I would do 3" spindles / Knuckles , and 2"rear coil spring spacers !
W
Wrenching09
I wouldn't max them out just a couple terms Ive installed keys for people before and other lift kits . Personally I wouldn't do a lift like that if you paid me took it off the last truck I owned that had them road awful and ate ball joints for breakfast . I'm wanting to see some 18s and 20s on stock height suspension so I know what looks better to me
All wheel drive? Tahoe or ???? It'd be nice to know more info about your vehicle. I'm pretty sure an all wheel drive tahoe does not exist
Is it a denali?
They didn't make an all wheel drive Yukon in 04 unless it was a denali. So I'm assuming it's most likely a 4wd that has an auto 4x4 option which isn't the same as all wheel drive. This kind of info is crucial when asking suspension related questions like you are so just trying to help :waytogo:
W
Wrenching09
I've always been a Ford guy til lately the last few vehicles have dissapointed me . Ford also sent me to college and I was a full certified auto tech for them for a few years but went to work for someone else with better pay and benefits . Soo I don't know the specifics of a lot of Chevys . I bought the Yukon because everyone I know has had amazing luck with the 5.3 and so I decided on a Tahoe or Yukon . It was referred to as AWD when looking at it, it was the first I had seen that way. It's as close to AWD as it gets but anyways that's what it is , looks like lift kits are crazy expensive so that's the reasoning behind stock height.
JochenWoern
Sacramento, CA
CORRECTION: I have an '04 Yukon SLT which has the All wheel drive feature, it is not 4x4
---------- Post added at 10:08 AM ---------- Previous post was at 10:04 AM ----------
What does the push button shift look like next to the steering column?
My 04 Yukon SLT does not have 4 wheel drive buttons either, I can only shift into a low mode, but it appears as it always runs on all wheel drive as there is no 2 hi option, I therefore assume it is also an all wheel drive.
JochenWoern
Sacramento, CA
It is same as yours ^^^
This is what mine looks like and therefore I would consider this an AWD, not a 4x4, as there are no 2 HI, 4 HI or AUTO 4X4 functions on the push button set up.
While driving, the light is always on and the symbol next to it would indicate to me that this is always in AWD. I can shift into 4LO when needed, but otherwise I would say she is in AWD at all times.
That looks more like an Auto 4x4 symbol with the top one being 2wd.
akaupp
Utah
In my limited research on this, it seems to be a one year only (2004) deal. From what I've read, it's basically auto 4wd with no option for 2 hi.
briannorris
