2.5" Front 1.5" Rear Leveling Kit Installed
milwaukeephil
I got my SuspensionMAXX leveling kit in a few weekends ago and wanted to share how it went. I actually ended up in the hospital at one point so it was truly a labor of love. The whole thing would have taken a total of about three hours if I had had a friend helping with prying or had 3 arms. Unfortunately I only have 2, and so when my pry bar slipped out from under my armpit and punched me right in that cartilage in my sternum I was out for the count for a few days.
Anyway, have a friend around to do the prying. The back is all fancy jack and jack-stand work. Absolutely zero effort.
The owner of SuspensionMAXX was ready on the phone the whole time, so that helped a ton. He really stands behind his products and I couldn't be happier with the support I got.
The hardest part was getting the front ball joint apart... it turned out to just need a lot of prying and a few really good whacks. By the way, the bottom of the ball joint has kind of a hidden allen wrench hole so to keep it from spinning when you put it back together. I didn't know this, and tried everything under the sun before I found it.
Here are some pics. I'm loving the ride and the height will be awesome for ice fishing this winter. I did go and get it aligned after it was all done.
Before:
During:
You can see the lower spacer in place here.
Rear spacer. Went in super easy. Watch your fingers.
After:
Kerrville15
Kerrville15
Kerrville, TX
Looks good. I was very pleased with the customer service from Suspension Maxx too. Here's a picture of my angles that I had promised.
triggerfin
I just ordered the suspension maxx kit for my 2015 Yukon XL 4WD. I am considering keeping the stock 20" wheels and replacing the tires with the 295/55-20 M/T Nittos. Any idea if these tires will work on the stock 20s? I can't find the exact specs on these factory wheels and I don't pick the truck up until Friday.
Kerrville15
Kerrville15
Kerrville, TX
Hard to get a pic of front CV angles when its two wheel drive :)
Rig looks good though!
I didn't even pay attention that he asked for CV angles. But you get the idea with with tie rod angles.
Yes they will work
triggerfin
I just installed the suspensionmaxx kit and thought I'd share my experience and hopefully help the next person.
In general, I felt like the instructions weren't completely accurate and/or could have provided a bit more detail. As with others, I also had to call them for help and they were very helpful - could not have done it without them. However, the calls could have been avoided with a bit more info.
I am extremely satisfied with the results.
Hope this helps.
Front:
- Step 2 under procedure says "Installation will be performed on both left and right sides together". This is an extremely important statement. You are not going to be able to get the first side you work on low enough to insert the spacers and reinstall the strut without unbolting the other side (or unbolting the sway bar). UNBOLT BOTH SIDES AT THE SAME TIME PRIOR TO ATTEMPTING TO INSTALL SHIMS AND SPACERS!
- Step 5 -- the nuts that are attached to the lower struts go away - that is, you need to pry them off the bottom of the strut and you won't re--use them; rather, you will use the new bolts included with the kit
- Step 12 FYI you don't need to remove the strut. Just lower it enough to put your shims and reinsert it.
- Step 16 - as others have stated, "lightly striking" the knuckle to unseat the ball joint isn't likely going to work. I had to strike mine with a heavy mallet, hard from multiple directions to get it to break free.
- Step 20 - I wasn't able to raise the A-Arm enough with the jack to come close to being able to insert the spacer between the a-arm and strut. 6' prybar also didn't get me there. Based on a call to suspensionmaxx, I had to use a bottle jack to get my jack point as far outward on the bottom of the a-arm as possible and you can only push that so far before it starts lifting your frame off your jackstands. Then, pry down on the a-arm and up on the strut coilspring (the pivot point is your A arm; the end of your prybar is in the coilspring - protect it with cardboard or cloth to prevent scratching the coating off your spring). That did the trick, giving me just enough room to insert the spacer. I would not have been able to do this without the bottle-jack and the pry-bar which was long enough for me to sit on. Could have done it with a 2nd (strong) person and a crowbar perhaps.
I also had problems with the rear. The instructions indicate you don't need to remove the tires. With my factory 20s and tires, you aren't likely going to be able to drop your axle enough to remove your springs with a floor jack and stands. So, I had to reposition everything, remove tires, get it as high as I could with the stands ,then drop my axle. IMPORTANT: it doesn't tell you that you need to unbolt the wiring at the axle (right above the rear differential). If you don't unscrew that bolt at the center of the axle, you're going to break those lines. Those things were under an extreme amount of tension when I realized what was going on - luckily I caught it in time and loosened it before lowering the axle any further. Also, the axle breather hose was stretched to the max by the time I finally got the axle low enough to get the springs out so watch that too - I couldn't figure out how to disconnect the hose so I just risked it.
Here are some b4 and after pics. I wanted to keep my factory 20" wheels and they seem to work well with the Nitto Trail Grapplers LT295/55R20/10. However, my tire shop wasn't able to do the alignment for me afterward (Note SuspensionMaxx does provide alignment specs) as they were worried they would damage the wheels, which protrude beyond the wall of the tire - advised me to take it to the dealer.
Rides like factory although the tires, as expected, are not quiet. I wish I'd gone with the Terra Grapplers, which I have on my 2002 Yukon and like very much.
Here are some b4 and after pics. I feel like I can use my Yukon XL like I need to use it now and like I use my '02 - on and around the farm, on the beach, camping, and taking the kids to school... Isn't that how SUV's were originally intended? Sorry to rant but if I'd wanted a minivan I had a lot of those to choose from - where'd the SUVs go?
jrmarsy
i installed same kit on my 2015 denali. The suspension fault light come on after install. They adjusted the links to clear out the fault. I am getting a squeak like noise when going slow over uneven terrain. Also, the rear suspension seems tight now. Any thoughts on adjustments to make to soften ride?
Floatindirty
Hows the ride? Any harsher than stock? Also my wifes is 4x4 but found out it has 3.08 gears anybody else have same gears and how bad does the power suffer?
coffeyman76
Hey guys I need some help. 2015 Denali 4wd. Getting the 2.5/1.5 Suspension Maxx Kit (or equivalent).
I would like to get the Black Rhino Sierra 20x9 wheels and Nitto Terra Grapplers. The wheels come in a -12 or +12 offset.
I don't want to cut and I don't want the tires extending much, if any, past the fender.
I am assuming I should order the +12 offset. With that I am leaning towards the 285/55R20 but it looks like you guys are having success with the 295/55R20? They look sharp.
With that offset and other parameters which one do you think is best, or am I completely off base????
SuspensionMaxx
Hope this helps.
Front:
Tgriffin
I appreciate the feed back. I will be updating the instructions in our kits to better help the DIY installers
Thanks
John @ SuspensionMaxx
Jac6586
Kerville15 - Your Yukon looks great. Wondering if you recall how dark you tinted the windows? The dark tint looks really good with the back wheels, really pulls it all together.
Also, are you still happy with the tire size that you went with? You mentioned in one of your earlier post that you had slight rubbing when backing out of your driveway, so just curious if you would still go with the 295's or if you would size down?
Lastly, did the leveling kit and larger tires kill your ride quality and gas mileage? I would imagine that it decreased, just wondering if it was drastic?
Thanks.
Kerrville15
Kerrville15
Kerrville, TX
Thanks.
As far as the tint goes I have no idea what percent it is, I just told them to match the rear tint from the factory.
After making some adjustments to the liner I have zero rub now. I would definitely stay with the 295s though; I feel like its the perfect size with the setup I have.
I feel like the Yukon rides just as good with the leveling as it did from the factory & wouldn't hesitate to do it again. Gas mileage did drop some after everything was put on. I get around 13 around town & 18 on the highway.
Wristdoc
Kerville15,
I love your truck! I am about to place an order for a 2015 Denali XL and would like to install your same lift. Do you think you have room for an extra inch of width on the tires such as with a 33x12.5x20? I wouldn't mind doing a little trimming of the plastic, etc, but obviously would need them to fit within the sheetmetal, etc. I don't mind some slight rubbing with full lock turns, etc but don't want anything to rub excessively.
I would appreciate any additional insight you can provide!
Thanks!
milwaukeephil
Found out the hard way today that the lift kit makes the stock jack useless when changing a flat tire. Luckily I was at the cabin and had some 2x6 scraps around to pile up, but if I had been on the side of the freeway I would have been screwed.
6point2lovelifers
