clandr1
Dallas/Fort Worth, Texas
Oh there is definitely damage... its still noisy. Im just hoping it holds up until tax return time...
I have driven about 2k miles since I first noticed it. Within that time it has started a weird metal tick/squeak. that was the noise that was hard to track down because its only under loaded acceleration.
Ah shit, man. That sucks.
Not sure if you plan to do the work yourself or take it somewhere, but Baertrax in Dallas regeared my '89 Jimmy a couple years back, and they seem to do solid work. I did the break in, changed the diff fluid, then immediately drove to Silverton, CO, did the Alpine Loop, then drove right back. No troubles with the new rear end at all.
Rear differential regeared to 4.10 (with two new axle shafts and all new bearings/seals) ran approx $1600 OTD if I remember correctly. However, I did buy and provide my own ring and pinion gear set, so you'll have to add that to the $1600. You might save about $500 if you don't need new axle shafts.
Tahoewhat
Ballin' on a Budget
TX
took third row out for some stuff to haul and realized that bt springs suck w/o a weighted down vehicle. Rode much better with more weight in the rear.
Mister H12
Undercover Racecar
West Tennessee
It was yesterday.. but note worthy... ran into a fckn black wolf dog in the middle of the night.
Note to self: Retrofit would have been real nice to have.
Side note: Didn't leave a scratch when i hit the thing :p
Physh1
Just got...
2007+ FRONT drilled & slotted R1 Concepts rotors...plus ceramic pads
00-06 REAR drilled & slotted R1 Concepts rotors...plus ceramic pads
Raybestos professional calipers FRONT & REAR...
Goodridge stainless lines...
New ACDelco parking brake shoes...
Headed out now to start ripping the Tahoe apart...
Cameron
chevync
North Carolina
Installed the Kicker Hideaway sub/amp. Wasn't to bad, put in under the second row of seats, right in the middle, cut a 2 inch place in the carpet then another one under the front center console so I could run the wires. Sounds good for a small enclosed 8" sub. Next will be the door speakers I have all 4 to replace with kenwoods two way speakers.
criffaaa1
The black dog is truckers lore, you feel asleep at the wheel, and the whole thing never happened. lol
At least it wasn't the fully dressed purple circus elephant i saw when i drove straight from Miami to Cleveland only stopping to fill up once. I was in the middle of bfn, and clearly saw the summamabitch standing in the highway. That ****** scared the shit outta me.
Sent from my LGLS990 using Xparent Purple Tapatalk 2
Tahoewhat
Ballin' on a Budget
TX
Just got...
Cameron
Your going to love the difference in stopping power. Got the calipers also right?
Big Buttons
The SS Burb
South Texas
Just got...
Cameron
In red :waytogo:
Tahoewhat
Ballin' on a Budget
TX
DOH' --- read to fast.
Still stick w/ post. Your going to love the stopping power. Bead them in when you get it all done and you will be set. ... Make sure nothing can be a projectile in the tahoe before you do the bead in process. lol seriously
Yuko04
"SquareBODluvr"
MN
SUBLETTKUSTOMZ
01ssreda4
Did they give you vaseline before they bent you over!!:893MrT-thumb:
Physh1
Yeah, I'm finally dropping some cash on the Tahoe...been sitting idle too long. I've put around 500 miles on it in the last year & a half...lol
I was going to buy everything from FreedomMotorsports but I couldnt get ahold of him. Bought the rotors & Goodridge lines from Amazon & the pads & calipers from work.
I've got coilover parts, a full front end rebuild, new upper & lower arms, complete hydroboost swap, & some misc items all sitting in the garage ready to go. Time to start the tear down. Also got a Esky roof rack coming...hopefully Thursday...
Cameron
Tahoewhat
Ballin' on a Budget
TX
Cameron
Roger must be away from for the time. He is a great guy to deal with. Bought all my stuff from him.
Sounds like you have quite the build going on. Be like driving a new tahoe again.
I want to do your NNBS running boards idea. Good luck with the tear down. Let me know how you like the brake setup.
rebl68
SE Michigan
put a new o2 sensor on the rear passenger side - no more CEL.
also redistributed the grease on the intermediate shaft - no more annoying clunks for the time being.
Smoke Em All
Taylor,Texas
Did my 4 low and 6 high mod! So cheap and easy!!
2003 Tahoe LT loaded!! 3" body lift Nitto Terra Grapplers 285/65/18..
Fosscore
Changed the oil and got a new O2 sensor installed to clear the CEL.
dawgofnate
Houston
Pulled the valve covers to find that I'm the owner of a sub 100k mile Tahoe that needs new heads because of the F'd up Castech fail. This is my first GM and I've only had the thing for 3000 miles too.
Buford bubba
