CCM leveling kit on 34s
Cshayes2
Tuscaloosa, Alabama
Just recently put my CCM 2.5/1 inch leveling kit on my Tahoe, did it myself, one of the factory mounting clips broke but other than that it was a smooth process. Got a great deal on some 275/65/r20 Toyo A/T II's, minor rubbing will fix that myself today also. Pictures below, bottom is right before install
cjweb11
Houston TX
probably the tallest tire ive seen on the CCM kit, looks good, really fills out the wheel wells. Looks great from the front with the airdam removed too
Cshayes2
Cshayes2
Tuscaloosa, Alabama
Thanks y'all.
Just got my rubbing issues fixed, just had to remove some of the plastic bolts that held the wheel wells in. while i was tinkering with it i measured the height of the fender from the ground and it measures at 39.75 in the front and 40.5 in the rear.
felixgun
Lafayette, LA
Wow a 34 on a 2.5/1 leveling kit? I have 33's on a 4/3 leveling kit and it's pushing it lol.
Cshayes2
Cshayes2
Tuscaloosa, Alabama
Yep, i read around and when the opportunity arose to see if the 34s would fit I took it, Topline tires installed them and said no rub, but when i got it home it rubbed on some plastic snap ins that hold the fender well in, after taking those out the rubbing is manageable (only when in reverse at full locks, but very worth it to me)
felixgun
Lafayette, LA
Do you know if it's like a 34.3 or 34.8? I'm thinking of going with a bigger tire for more sidewall since I have 22's and I found 2 sets of 34's that I really like.
Cshayes2
Cshayes2
Tuscaloosa, Alabama
34.01, and my toyos came exactly 34 inches with a tape measure, id suggest them if its an option.
dizhai
