Which roll pan/ hidden hitch?
YNOT
I'll be getting a 00-06 Tahoe anyday now and I want to hit the ground running with mods.
What brand roll pan and hidden hitch should I go with? Or even better which brands should I stay away from?
JKmotorsports
Austin, TX
Sir Micheals makes a good rollpan and hidden hitch set-up. Street Scenes has a nice urethane rollpan with nice contours, which is the one I have with a Sir Micheals' hidden hitch.
YNOT
YNOT
so did that ss urathane pan come with the hitch hole already there? plate lights? or did you have to dremel those holes in? where did you buy yours from?
---------- Post added at 07:49 PM ---------- Previous post was at 07:42 PM ----------
just did some looking and those are really the only 2 choices, besides scary ebay brands. i think i'll go with the cheaper one and get the urathane.
---------- Post added at 07:50 PM ---------- Previous post was at 07:49 PM ----------
oh and did you buy a $10 rollpan light or did you do something else. thanks for the help, i'm going to look at a white 03' tahoe tomorrow and i want to strip parts of it and get straight to the colormatching.
YNOT
YNOT
oh and can you still run the spare with your ss pan and sir micheals hid-a-hitch?
JKmotorsports
Austin, TX
There's a license plate light kit available, but I used the stock lights and used a dremel to cut the openings for the stockers.
The Sir Micheals hitch still allows you to keep the spare tire and most roll pans come with an opening for the hitch. You'll have to buy a flip-up license plate bracket as well so you can have access to the hitch.
Front Street
Mpls/St.Paul
Since Sir Michael's is out of business, does anyone have another option for a hidden hitch where I can keep the spare tire? Is Stillen/Street Scene the only option besides a custom fabrication job?
Thanks all!
jomulk56
Resident Lurker
IN
anyone have a rollpan with barn doors? is there even a difference?
Pirana/Big-T RS00P fiberglass rollpan $79.95 + shipping www.streetpros.com it fits like a dream and is held on with about 10 screws.
4F584AC9-9610-49FF-B72B-347F30DB4426_zpsotitgfwx by jomulk56, on Flickr
Thanks all!
When I was looking a few months ago I found one other company that makes them. http://www.trucknvans.com/product/Hidden-Rollpan-Towing-Hitch Hope that helps
Zumwalt
El Paso, TX
That street pros is nice, does it have the hole for lowering spare? Or is it drill your own
Sent from my SGH-T999 using Tapatalk
jomulk56
Resident Lurker
IN
No pre drilled hole, I'm sure you could add one tho. I didn't worry about it because my spare was gone when I bought it, and the assembly was inoperable so I removed it.
chicksdigit
Definitely go with metal, there I has gotta be another company that makes metal roll pans besides sir Michaels. I always used their's personally
jomulk56
Resident Lurker
IN
People choose different material for different reasons. Metal is probably the best but it costs more to start, then it has to be welded in, and it's not nearly as forgiving as a urethane or fiberglass if you hit something. Now urethane and fiberglass are easy to install yourself so you save money there, but they can crack/sag with very extreme weather changes. I personally have never had an issue with anything urethane on any vehicle tho. Just my opinions.
Sent from Tapatalk
OldWYLawman
