2008 GMC Yukon Denali XL - Stalling at highway speed - SCARY
daddyrim
Timmins, on
My 2008 GMC Yukon Denali has once again failed in the same manner as it did the first weekend of March, though this time, the incident could have resulted in a serious if not fatal incident had the conditions been worse.
For the second time, our Yukon has shut down while driving and is unable to restart. This time however, it occurred at highway speeds at night while returning from a hockey tournament with a vehicle full of hockey players and parents. While letting off the accelerator pedal in preparation to slow down and turn onto another highway, the engine shut down resulting in no power steering, power brakes etc. The vehicle was able to be negotiated to the side of the road, luckily safely. Again, the truck was able to be turned over normally, attempting to restart, but would not catch, the same as had occurred 5 weeks ago.
The previous diagnosis and repair by the GM dealer indicated a battery failure in March for the same symptoms we experienced this past Friday. Given the same symptoms, a nearby friend was called and came with a ¾ ton` diesel pickup to attempt a boost, along with a voltage tester. The battery tested at 12.7v, and even with booster cables connected turned over as it had before, but would not fire up. The truck turned over just fine with or without the boost, but would not start.
As a result the truck was towed again.
My concern is that previous occurrence / diagnosis has missed something, and that the same has occurred once again. The previous failure in early March occurred at slow speeds in a parking lot, this time it was at highway speed, which is of great concern to us for safety reasons. Had this failure occurred on a busier highway (we’re in southern Ontario often) or towing our travel trailer, the results could have been disastrous.
I have found several instances of this very same issue online with an assortment of suggested fixes, which in many cases did not remedy the situation resulting in the owner selling the vehicle in frustration. I trust that I will not find myself in this same situation.
I'm looking for feedback from anyone else on this issue board as I'm concerned the dealer will again miss the problem.
khaleej
hey there, you have given a great description about the hockey players but not about the car :p .
Does the engine cranks.
Did you diagnose it for any dtc.
i will be waiting for your answer.
daddyrim
daddyrim
Timmins, on
Sorry if I wasn't clear in my description. By "turning over" I meant engine "cranks". In both instances the engine cranked without issue but would not run.
I did not diagnose for any DTC. Towed to dealer.
daddyrim
daddyrim
Timmins, on
Dealer hasn't had any luck reproducing the incident. Of course after sitting for the weekend the truck started right up for them without any issues. Because of the nature of the failure they are keeping it and inspecting it again today to try and reproduce the failure.
Unfortunately no error codes were present, which I can't understand given that it simply shut down and would not restart no matter how many times we cranked the engine.
khaleej
without codes, the dealers will be help less. there are many reasons for car being shut off .
May be a bad fuel pump or a crankshaft position sensor . did the car start immediately after towing or they did something.
its really wierd.
next time if the car turns off and will not start then check the coil for any spark.if no spark then it will be a faulty crank sensor
---------- Post added at 09:38 AM ---------- Previous post was at 09:33 AM ----------
its really wierd.
CrashTestDummy
Pearland, Texas
As others have mentioned, check for spark next time. Also, you may want to invest in a fuel pressure gauge, so you can verify that the fuel pump is functioning. Just throw it in the glove box for next time. You may have something heating up and shutting down, like the crank trigger, some relay, or fuel pump.
GM Customer Service
Michigan
Hi daddyrim,
We’re so sorry to hear of this happening with your Yukon Denali. Please feel free to contact GM of Canada if you need any further assistance with this concern. Their number is 800-263-3777 and can be reached Monday through Friday from 7:30 AM until 11:30 PM and Saturday from 7:30 AM until 6:00 PM EST. Please let us know if you have any questions. Thank you.
Kristen A.
GM Customer Care
daddyrim
daddyrim
Timmins, on
Thank you everyone for your replies.
Update. The dealer kept the truck for another day, drove it and let it idle, and did not replicate the problem. We retook possession of it as rental costs were mounting.
GM Canada contacted me and are looking into the issue as it is the second documented but unresolved occurrence.
With regards to the fuel pressure test, can someone direct me as to an easy way to test this as I'm not familiar with any port etc where this can be done, especially if this happens again on the side of the road.
brice715
