Well, that Escaladed quickly!
THE YETI
Director of Operations
South FL
Thanks gentleman, those Willwoods are sexy for sure. Would it be a bad idea if I just did the fronts, or did willwood up front and r1 in the rear?
Sent from my SCH-I545 using Tapatalk 2
Just do the fronts until you can afford the rears. We had that setup for a bit on the suburban.
shundal
NorCal
Escalade looks perfect. Were any modifications to the bumper needed to fit the corsa tips? I was able to get an awesome deal on a premium bumper from a local dismantler, and want to have my corsa sport setup the way yours is.
soulsea
soulsea
Bar
No mods at all, took the shop less than 20 minutes to swap the stock exhaust to the Corsa.
shundal
NorCal
Thanks. That's good to know. I'll have to get the bumper to the paint shop ASAP so I can get this done. It's the last mod I will be doing.
THE YETI
South FL
HAHA, I'm going to try my best to keep it my last. But if some wilwood calipers will work with my Baer Eradi speed 15 inch rotors, I might have one big mod left in me...
Those won't work, but the Z06 6-piston calipers will. ;)
shundal
NorCal
Yea I wanted to do the z06 or cts-v calipers, but wasn't able to find anyone making brackets to work on the nnbs tahoe
GalaxyBlackEsky
BlackedoutLT3
MD
Yeah I have thought about doing yellow CTS-V brakes and have my brother design and machine the brackets.
THE YETI
South FL
Why not use the ones for the NBS and make them work? Fabricate fabricate!
---------- Post added at 11:10 PM ---------- Previous post was at 11:10 PM ----------
Why not use the yellow z06 ones? They are 6 piston. I think the CTS are 4 piston.
shundal
NorCal
That might be my only option. If there was an easier bolt on solution, it would encourage me to do this quicker. I know that the 2012 cts-c have 6 piston calipers, but i'm not sure if they are any different that the z06.
bigmiker21
Senior Member
Central Ohio
I will do the fronts for now and get rears after some OT, but i need some 22's!! The BBK won't fit with the factory wheels on it. hint.. hint.. :D
GalaxyBlackEsky
BlackedoutLT3
MD
Actually the New CTS-V's are 6 piston in the front. They are just a tad different looking then the Z06's. But I can't find any Z06's in yellow. But I can find CTS-V's in yellow for about 100 more. If I can find cheaper Z06's then I will powder coat them. As for finding NBS brackets I can't find them anywhere. So I will just let my brother measure and make them. He is a mechincal engineer. If I go that route. I have to see what coast is and decide if it is just better to do wilwoods.
THE YETI
South FL
I spent right around $1500 on my Z06 brake setup. $300 of that was just the brackets. That should give you a good idea of where you'd be after it was all said and done. That was for all brand new parts. Labor was free, I did it myself.
I can tell you that the wilwood kit was ALOT better than the Z06 setup I had.
There was a guy on silveradoss.com who had a bunch of the brackets left. His username was Rudy.
Smokymance
Boosted
MI
What do the vette calipers vs wilwoods cost? im liking all this info....im a brake ME :party36: too bad i didnt know abou this 4 years ago...i used to work on all the V brakes...
---------- Post added at 08:55 AM ---------- Previous post was at 08:54 AM ----------
never mind...yeti answered that question as i was typing it!!!!!!! :drunk:
soulsea
soulsea
Bar
I went back to the same spot to take some after pics after the slight additional rear drop to see if it shows the difference:
Before:
After:
Before:
After:
Before:
After:
Before:
After:
OHSIXX
Milwaukee
You can definitely see the difference.........you have my favorite ride on the TYF...Well Done!
Drewphil
