Well, that Escaladed quickly!
soulsea
soulsea
Bar
did you happen to know what your link length is, either from ball stud center point to center point or over all length of the link and end caps?
I'm sorry Lee, I don't know that ... actually I don't even know what most of that sentence means. :(
Here's a quick pic cause I haven't had time to take proper ones ... you're not going to be able to tell the difference from the previous pics cause it basically only went down half an inch.
Not sure exactly how that works because I replaced a 1" spacer with a 1/4" spacer, so you'd think the truck ass would go down 3/4", but no, it went down 1/2". :shrug:
Ride is good, but I wouldn't want to go any lower. And the shop I took it at has 1/4" inch spacers so they can add and subtract height by that increment as required by the customer.
That is sitting at almost perfectly level it appears on that pic. Nicely done :)
Smokymance
Boosted
MI
LOL...i basically was asking what the length of the links were...
u removed 3/4 of the spacer, but truck only went down 1/2 cause your air ride compensates for it and lifted it up a tad...if you play with the link length a bit, you can bring it down further
soulsea
soulsea
Bar
Maybe that's the pic ... I'm 34" up front and exactly 35.5" at the back.
---------- Post added at 01:48 PM ---------- Previous post was at 01:46 PM ----------
I don't think that's it, the links and bumpstops were cut to adjust for the 3/4" drop, and the compressor hasn't turned on once since the spacer swap. I suspect it's got to do with how the coils work, but I don't know enough about it to be sure.
Stupid 1.5" rake
soulsea
soulsea
Bar
I like the factory rake, just not at factory height. :)
Plus before today I had a 2" rake.
Smokymance
Boosted
MI
Looks perfect...i need to find the 1/4 spacers like you...i had my one 1 spacers off and was too low when compressor didnt kick on...i have my 1in spacers in now, ride is way better but its too raked...
GalaxyBlackEsky
BlackedoutLT3
MD
That does look good. At least I can tell it is a little more level. I am afraid of taking the spacer completely out as well. As it will be to low and ride will be affected. I am putting in the spindles next Monday. Got a lift to do it on. Body shop guy is helping me do it for free.
OHSIXX
Milwaukee
Looks even better.....I'd hang onto your Esky over any new 2015 model.....done to near perfection!
soulsea
soulsea
Bar
Thanks guys ... the new esky hasn't grown on me yet. That might change when I see them in person, but right now I wouldn't trade my truck for any other. :)
THE YETI
Director of Operations
South FL
Oh really? ;)
NathanJax
Vacation Nathan
Jax, Fl
Looks good Serge!!!
bigmiker21
Senior Member
Central Ohio
Damn I've been looking for some wheels and brakes. But 4k is a little steep for my blood right now, did you order straight from wilwood? Any other brake kits recommended for my future 22's ?
soulsea
soulsea
Bar
I think Baer and Stop Tech kits are cheaper, although I'm not sure how good they are, and I've read that Baer calipers are bigger so more clearance is needed.
Another option that I like are R1 Concept rotors with Posi-Quiet pads. They perform well and are more than adequate for 22's. The probably don't have the "wow" factor of Willwoods or Baer but they perform very well and are durable.
Anyway, just another option for you to consider. Freedom Motorsports (TYF vendor) sells them on here. You can get the Willwoods from JennaBear (also a TYF vendor). Both are top notch to work with and I've bought from both of them :waytogo:
bigmiker21
Senior Member
Central Ohio
Thanks gentleman, those Willwoods are sexy for sure. Would it be a bad idea if I just did the fronts, or did willwood up front and r1 in the rear?
Sent from my SCH-I545 using Tapatalk 2
Drewphil
